KC868 A8 + Home Assistant + DS18B20+
Good afternoon! I bought two KC868 A8 and KC868 A16 boards to use with Home Assistant. I found configuration files for these boards on a forum, and all the inputs/outputs work, but I can't connect the sensors. Help please.
download KCS v2 firmware, set the sensor by "sensor" webpage.
here is KCS v2 online guide: https://www.kincony.com/esp32-kcsv2-firmware.html
Good afternoon! But I'm using a board with Home Assistant. If I install the KCS firmware, will I be able to control the KC868 board using Home Assistant?
sure. there are two way use for home assistant.
1: download KCS firmware, integrate to home assistant by MQTT.
2: config by ESPHome.
I would like the second option.
Наиль, 1 Guest(s)
