Yesterday, 10:41 AM
I noticed an issue with the MQTT Discovery configuration generated by the N30 when the device is integrated into Home Assistant.
For example, Home Assistant creates the following entity:
The N30 publishes this MQTT Discovery payload:
In Home Assistant, the entity is therefore detected with:
but without:
The missing field in the MQTT Discovery payload is:
Interestingly, some other N30 power sensors are correctly detected by Home Assistant with:
For example,
already has the correct
This suggests that the issue is specific to some of the MQTT Discovery configurations generated by the N30 firmware, particularly the
sensors.
Could you please check the N30 firmware and add:
to the MQTT Discovery configuration of all instantaneous power sensors?
The expected configuration would be:
This would allow Home Assistant to correctly identify these entities as power measurements and use them properly for statistics and energy-related features.
Thank you.
sensor.n30_d0cf13020244_energy2_ch2_powerCode:
"uniq_id": "D0CF13020244_sensor_energy2_power_ch2",
"~": "homeassistant/sensor/D0CF13020244energy2_power_ch2",
"name": "energy2_ch2.power",
"device": {
"name": "N30-D0CF13020244",
"identifiers": "D0CF13020244",
"manufacturer": "KinCony",
"model": "N30"
"config_topic": "~/config",
"avty_t": "D0CF13020244/avail",
"unit_of_meas": "W",
"dev_cla": "power",
"val_tpl": "{{ value | float | round(1) }}",
"stat_t": "~/state"
}Code:
device_class: power
unit_of_measurement: WCode:
state_class: measurementCode:
"stat_cla": "measurement"Code:
device_class: powerCode:
sensor.n30_bl0910_1_power_6Code:
state_classThis suggests that the issue is specific to some of the MQTT Discovery configurations generated by the N30 firmware, particularly the
energy*_ch*_powerCould you please check the N30 firmware and add:
"stat_cla": "measurement"The expected configuration would be:
"dev_cla": "power",
"stat_cla": "measurement"Thank you.
