08-30-2026, 11:58 PM
Made by KinCony IoT: https://www.kincony.com
Program functionality:
This program uses an ESP32-S3 to read inputs from an XL9535 I/O expander chip
(I2C address 0x24) via I2C. The XL9535 chip handles channels 1-16.
The program reads the state of all these inputs and prints them in binary format
to the serial monitor.
Key points:
- The I2C bus is initialized on GPIO pins 8 (SDA) and 18 (SCL) with a frequency of 40kHz.
- The XL9535 chip reads the state of input pins for channels 1-16.
- The state of the inputs is printed to the serial monitor in binary format every second.
- Note: The original description mentioned three expander chips, but this implementation
currently uses only one XL9535 (PCA9555 compatible) at address 0x24.
#include <PCA95x5.h>
#include <Wire.h>
// Initialize the PCA9555 object for XL9535 chip (channels 1-16)
PCA9555 ioex1; // XL9535 I/O expander at I2C address 0x24, handles channels 1-16
delay(2000); // Wait for 2 seconds to ensure serial monitor is ready
// Initialize the I2C bus with GPIO 8 as SDA and GPIO 18 as SCL, 40kHz frequency
Wire.begin(8, 18, 40000);
// Attach the PCA9555 device at I2C address 0x24
ioex1.attach(Wire, 0x24);
// Set polarity to original (no inversion)
ioex1.polarity(PCA95x5::Polarity::ORIGINAL_ALL);
// Configure all 16 pins as inputs
ioex1.direction(PCA95x5::Direction::IN_ALL);
// Read and print the state of inputs from the XL9535 (channels 1-16)
Serial.print("1-16 input states: ");
// Read all 16 pins and print as 16-bit binary value
Serial.println(ioex1.read(), BIN);
delay(1000); // Wait for 1 second before the next reading
2-digital-input.zip (Size: 1,013 bytes / Downloads: 24)
2-digital-input.ino.merged.zip (Size: 197.84 KB / Downloads: 30)
