IFTTT
I wanted to use KCS firmware and IFTTT to control a relay on and off, by using an adc input from a potentiometer which would act as the temp setpoint, then if actual temp measured by temp sensor was below the adc setpoint, it switches the relay on.   Problem seems to be you cannot use the actual adc value in ifttt to comapre to the temp sensor value(unless you tell me otherwise).  So it looks like I will have to use arduino code.  So my question would be how do i then monitor all the inputs, outputs, sdcvalues  and temp sensors etc.  Do I have to use home assistant or arduino web server Tasmota etc ??  no isea what is the best way to do this ?
TIA
if you can write arduino code, you can read anything do any automation. the analog input and digital output , all have arduino demo code in our forum.
(Yesterday, 01:29 AM)admin Wrote: if you can write arduino code, you can read anything do any automation. the analog input and digital output , all have arduino demo code in our forum.
Yeah I get that bit and I Can write the ocde but withouth your KCS foirmware on the board how do I monitorand see all the port statuses etc??
i suggest you run our arduino demo code firstly, you will understand.
ok cheers - already got home assistant up and runing from scratch with esphome and your kc868-a16 YAML file. one question when did I have to invert all the pins to get the correct status ?
our A16 demo yaml just directly to use.
(Yesterday, 01:14 PM)admin Wrote: our A16 demo yaml just directly to use.
Sorry no this is your latest code from website i believe,  and for the kc868-a16 rev1.6 this needs to be changed to TRUE - i also noticed an image someone else put on showing they had changed them to true as well.  It needs to be done for inputs and outputs just so you are aware
you can test set to "true", whether work well.
(Today, 12:41 AM)admin Wrote: you can test set to "true", whether work well.
Set it to true and it woeks as it should ie. when switch on led on board is on
ok, so you just set to "true"
