10-12-2026, 01:48 PM
I wanted to use KCS firmware and IFTTT to control a relay on and off, by using an adc input from a potentiometer which would act as the temp setpoint, then if actual temp measured by temp sensor was below the adc setpoint, it switches the relay on. Problem seems to be you cannot use the actual adc value in ifttt to comapre to the temp sensor value(unless you tell me otherwise). So it looks like I will have to use arduino code. So my question would be how do i then monitor all the inputs, outputs, sdcvalues and temp sensors etc. Do I have to use home assistant or arduino web server Tasmota etc ?? no isea what is the best way to do this ?
TIA
TIA
