Threads: 1,322
12-03-2020, 02:27 AM
(This post was last modified: 03-19-2021, 05:50 AM by admin.)
update: when power on of KC868-COL, autoreport analog and temperature value at least one time.
Threads: 4
What is change in this version in compare with older V1.0.17
Can not recognize any differences. I already suggested you should make Upgrades List for users.
Thanks.
Threads: 1,322
already writen in first floor.
Threads: 1,322
old version of KC868-COL firmware, when enable "Auto Report" function, when input data is changed then will begin upload data to PC software, if input data is not changed, will not upload any data to PC. now the V1.0.18 firmware of KC868-COL, it will send data one time even if input data is not changed.so that PC windows can see the state.
Threads: 0
Hello! please tell me how can i upgrade my 868-col controller? I tried to do it with the "KC868 Controller Bootloader", but when connected, the program does not find the bootloader. Maybe you need other software for that?
Threads: 1,322
update only for KC868-COLB. do you using COLB, not COL ?
if using COLB, use this "KC868 Controller Bootloader" is right. you must click "detect" button <5 seconds when power on.
