K868-A8 flashing configuration ?
Hi
What is the exact procedure to flash that device ? and please don't send me your useless youtube videos !! I have applied 12V on board (board starts well) I plugged the USB cable between my computer or my Home assistant system and the board but ESPHome never succeeds to communicate through the USB port to flash the board Sad Got no problem to flash the K868-AG and the K868-Uair but not that device..
Here is my basic code used for now:
substitutions:
  friendly_name: kincony-k868-a8
  platform: ESP32
web_server:
ota:
wifi:
  networks:
  - ssid: !secret wifi
    password: !secret wifi_passwd
  - ssid: !secret wifi_puppy
    password: !secret wifi_puppy_passwd
  ap:
    ssid: $friendly_name
captive_portal:
  reboot_timeout: 120min
Thanks
Vincèn
here is KC868-A8 ESPHome config file. it can directly to use.
.zip   Made_for_ESPHome_KC868-A8.zip (Size: 759 bytes / Downloads: 852)
(03-13-2022, 01:42 AM)admin Wrote: here is KC868-A8 ESPHome config file. it can directly to use.
Can you please read messages and answer properly ? I don't need ESPHome code for it ! I need to know how to flash it as I explained my process in my previous message but it doesn't work Sad
Thanks
when using EPSHome on home assitant download chose USB-Serial port. you should take photo or video is better to describe your problem! so that we can know how you download, what's your step have done. This process have showed in many demo videos.
(03-14-2022, 11:16 AM)admin Wrote: when using EPSHome on home assitant download chose USB-Serial port. you should take photo or video is better to describe your problem! so that we can know how you download, what's your step have done. This process have showed in many demo videos.
Well I use same process as to flash K868-AG and K868-Uair ! It worked without problems with these devices but not the K868-A8 Sad That's why I'm asking if there is something specific to flash that device or basically power and usb cable is enough ?
OLÁ, MINHA PLACA TAMBÉM NÃO CARREGA O CODÍGO FORNECIDO. (K868-A8) ESTOU USANDO UMA VM.
NFO Programa compilado com sucesso.
INFO Resolvendo o endereço IP de kc868-a8.local
ERRO Erro ao resolver o endereço IP de kc868-a8.local. Ele está conectado ao Wi-Fi?
ERRO (Se o erro persistir, defina um endereço IP estático: https://esphome.io/components/wifi.html#manual-ips)
ERRO Erro ao resolver endereço IP: Erro ao resolver endereço com mDNS: Não respondeu. Talvez o dispositivo esteja offline., [Errno -5] Nenhum endereço associado ao nome do host
(05-31-2022, 08:40 PM)WAGNER RAMOS Wrote: OLÁ, MINHA PLACA TAMBÉM NÃO CARREGA O CODÍGO FORNECIDO. (K868-A8) ESTOU USANDO UMA VM.
take a photo of your problem. i don't understand your question.
ERRO Erro ao resolver endereço IP: Erro ao resolver endereço com mDNS: Não respondido. Talvez o dispositivo esteja offline., [Errno -5] Nenhum endereço associado ao nome do host
tire uma foto do seu problema. não entendi sua pergunta.
which board you are using? take a photo how you connect with wires.
(06-02-2022, 12:51 AM)administrador Wrote: qual placa você está usando? tire uma foto como você se conecta com os fios.
Ola, funcionou perfeitamente, Obrigado.
