04-15-2022, 02:21 AM
improvement:
add manufactory test commands for RS232
command-1 for set to test mode:
set static IP:192.168.1.200 for ethernet
set wifi work mode=TCP Server
set ethernet work mode=TCP Server
enable 4 chanenl analog input auto report
set board RS485 address=1
set board RS485 Baud rate=9600bps
command-2 for Restore factory settings:
set wifi work mode=UDP
set ethernet work mode=UDP
disable 4 channel analog input auto report
KC868_SERVER_V148_220413.zip (Size: 54.15 KB / Downloads: 797)
download the ZIP file , unzip update the bin file for KC868-H32B relay controller by USB-RS232 cable or ethernet cable.
