Threads: 1
1. Do you have any update from your testing?
Threads: 1,529
1. Do you see my feedback? no this problem, check your home assistant or Node-red other nodes, must have query for every 2 seconds.
Threads: 1
OK, i will re-install HA and node-red again. For clearly
Threads: 1,529
i think you can install only Node-Red for a test firstly.
Threads: 1
HI, i got the problem now. it stop after i disable esp32 Developer mode in relay setting.
if i turn it on for homekit use, the debug message running. Why, How can we stop it event turn ON Esp32 Developer mode?
Threads: 1,529
you want to use Apple Homekit , but not want the feedback message to TCP ?
Threads: 1
yes, i want to use homekit but don't need feedback message.
Threads: 1,529
ok, we will check, then feedback to you.
