08-24-2022, 12:46 AM
[Arduino IDE demo source code for KC868-A32]--#07-KC868-A32_Web_server_code
KC868-A32_Web_Server.zip (Size: 483.68 KB / Downloads: 760)
* Create Your own WebServer for KC868-A32 Smart Controller*
* https://www.kincony.com **
// Load Wi-Fi library
#include <WiFi.h>
#include "PCF8574.h"
#include <WiFiManager.h>
#define TRIGGER_PIN 0 // reset wifi button
WiFiManager wm;
// Replace with your network credential
/* const char* ssid = "xxx"; //your router's ssid
WiFiServer server(80);
String header;
// Current time
// Previous time
int flag_read_di=0;
TwoWire I2Cone = TwoWire(0);
TwoWire I2Ctwo = TwoWire(1);
PCF8574 pcf8574_R1(&I2Ctwo, 0x24, 15, 13);
PCF8574 pcf8574_R2(&I2Ctwo, 0x25, 15, 13);
PCF8574 pcf8574_R3(&I2Ctwo, 0x21, 15, 13);
PCF8574 pcf8574_R4(&I2Ctwo, 0x22, 15, 13);
PCF8574 pcf8574_I1(&I2Cone, 0x24, 4, 5);
PCF8574 pcf8574_I2(&I2Cone, 0x25, 4, 5);
PCF8574 pcf8574_I3(&I2Cone, 0x21, 4, 5);
PCF8574 pcf8574_I4(&I2Cone, 0x22, 4, 5);
String relaystate[32]={
"relay1state","relay2state","relay3state","relay4state","relay5state","relay6state","relay7state","relay8state",
"relay9state","relay10state","relay11state","relay12state","relay13state","relay14state","relay15state","relay16state",
"relay17state","relay18state","relay19state","relay20state","relay21state","relay22state","relay23state","relay24state",
"relay25state","relay26state","relay27state","relay18state","relay296state","relay30state","relay31state","relay32state",
String relay32state = "off";// state of relay32
for(int i=0;i<=7;i++)
pcf8574_R3.pinMode(i, OUTPUT);
pcf8574_R4.pinMode(i, OUTPUT);
pcf8574_R1.begin();
pcf8574_R2.begin();
pcf8574_R3.begin();
pcf8574_R4.begin();
for(int i=0;i<=7;i++){
pcf8574_I1.pinMode(i, INPUT);
pcf8574_I2.pinMode(i, INPUT);
pcf8574_I3.pinMode(i, INPUT);
pcf8574_I4.pinMode(i, INPUT);
pcf8574_I1.begin();
pcf8574_I2.begin();
pcf8574_I3.begin();
pcf8574_I4.begin();
pcf8574_R3.digitalWrite(i, HIGH);
pcf8574_R4.digitalWrite(i, HIGH);
// Connect to Wi-Fi network with SSID and password
// Serial.print("Connecting to ");
// Serial.println(ssid);
WiFi.mode(WIFI_STA);
//WiFi.begin(ssid, password);
bool res;
// res = wm.autoConnect(); // auto generated AP name from chipid
res = wm.autoConnect("KC868-A32-AP"); // anonymous ap
// res = wm.autoConnect("AutoConnectAP","password"); // password protected ap
if(!res) {
// ESP.restart();
else {
/*while (WiFi.status() != WL_CONNECTED) {
// delay(10);
//Serial.print(".");
ScanKey(); //scan key
Serial.println("");
server.begin();
void loop(){
currentTime = millis();
previousTime = currentTime;
header += c;
client.println();
// turns 16 relays on and off
else if (header.indexOf("GET /7/on") >= 0) {relay7state = "on";pcf8574_R1.digitalWrite(P6, LOW);}
else if (header.indexOf("GET /8/on") >= 0) {relay8state = "on";pcf8574_R1.digitalWrite(P7, LOW);}
else if (header.indexOf("GET /9/on") >= 0) {relay9state = "on";pcf8574_R2.digitalWrite(P0, LOW);}
else if (header.indexOf("GET /10/on") >= 0) {relay10state = "on";pcf8574_R2.digitalWrite(P1, LOW);}
else if (header.indexOf("GET /11/on") >= 0) {relay11state = "on";pcf8574_R2.digitalWrite(P2, LOW);}
else if (header.indexOf("GET /12/on") >= 0) {relay12state = "on";pcf8574_R2.digitalWrite(P3, LOW);}
else if (header.indexOf("GET /13/on") >= 0) {relay13state = "on";pcf8574_R2.digitalWrite(P4, LOW);}
else if (header.indexOf("GET /14/on") >= 0) {relay14state = "on";pcf8574_R2.digitalWrite(P5, LOW);}
else if (header.indexOf("GET /15/on") >= 0) {relay15state = "on";pcf8574_R2.digitalWrite(P6, LOW);}
else if (header.indexOf("GET /16/on") >= 0) {relay16state = "on";pcf8574_R2.digitalWrite(P7, LOW);}
else if (header.indexOf("GET /17/on") >= 0) {relay17state = "on";pcf8574_R3.digitalWrite(P0, LOW);}
else if (header.indexOf("GET /17/off") >= 0) {relay17state = "off";pcf8574_R3.digitalWrite(P0, HIGH);}
else if (header.indexOf("GET /18/on") >= 0) {relay18state = "on";pcf8574_R3.digitalWrite(P1, LOW);}
else if (header.indexOf("GET /18/off") >= 0) {relay18state = "off";pcf8574_R3.digitalWrite(P1, HIGH);}
else if (header.indexOf("GET /19/on") >= 0) {relay19state = "on";pcf8574_R3.digitalWrite(P2, LOW);}
else if (header.indexOf("GET /19/off") >= 0) {relay19state = "off";pcf8574_R3.digitalWrite(P2, HIGH);}
else if (header.indexOf("GET /20/on") >= 0) {relay20state = "on";pcf8574_R3.digitalWrite(P3, LOW);}
else if (header.indexOf("GET /20/off") >= 0) {relay20state = "off";pcf8574_R3.digitalWrite(P3, HIGH);}
else if (header.indexOf("GET /21/on") >= 0) {relay21state = "on";pcf8574_R3.digitalWrite(P4, LOW);}
else if (header.indexOf("GET /21/off") >= 0) {relay21state = "off";pcf8574_R3.digitalWrite(P4, HIGH);}
else if (header.indexOf("GET /22/on") >= 0) {relay22state = "on";pcf8574_R3.digitalWrite(P5, LOW);}
else if (header.indexOf("GET /22/off") >= 0) {relay22state = "off";pcf8574_R3.digitalWrite(P5, HIGH);}
else if (header.indexOf("GET /23/on") >= 0) {relay23state = "on";pcf8574_R3.digitalWrite(P6, LOW);}
else if (header.indexOf("GET /23/off") >= 0) {relay23state = "off";pcf8574_R3.digitalWrite(P6, HIGH);}
else if (header.indexOf("GET /24/on") >= 0) {relay24state = "on";pcf8574_R3.digitalWrite(P7, LOW);}
else if (header.indexOf("GET /24/off") >= 0) {relay24state = "off";pcf8574_R3.digitalWrite(P7, HIGH);}
else if (header.indexOf("GET /25/on") >= 0) {relay25state = "on";pcf8574_R4.digitalWrite(P0, LOW);}
else if (header.indexOf("GET /25/off") >= 0) {relay25state = "off";pcf8574_R4.digitalWrite(P0, HIGH);}
else if (header.indexOf("GET /26/on") >= 0) {relay26state = "on";pcf8574_R4.digitalWrite(P1, LOW);}
else if (header.indexOf("GET /26/off") >= 0) {relay26state = "off";pcf8574_R4.digitalWrite(P1, HIGH);}
else if (header.indexOf("GET /27/on") >= 0) {relay27state = "on";pcf8574_R4.digitalWrite(P2, LOW);}
else if (header.indexOf("GET /27/off") >= 0) {relay27state = "off";pcf8574_R4.digitalWrite(P2, HIGH);}
else if (header.indexOf("GET /28/on") >= 0) {relay28state = "on";pcf8574_R4.digitalWrite(P3, LOW);}
else if (header.indexOf("GET /28/off") >= 0) {relay28state = "off";pcf8574_R4.digitalWrite(P3, HIGH);}
else if (header.indexOf("GET /29/on") >= 0) {relay29state = "on";pcf8574_R4.digitalWrite(P4, LOW);}
else if (header.indexOf("GET /29/off") >= 0) {relay29state = "off";pcf8574_R4.digitalWrite(P4, HIGH);}
else if (header.indexOf("GET /30/on") >= 0) {relay30state = "on";pcf8574_R4.digitalWrite(P5, LOW);}
else if (header.indexOf("GET /30/off") >= 0) {relay30state = "off";pcf8574_R4.digitalWrite(P5, HIGH);}
else if (header.indexOf("GET /31/on") >= 0) {relay31state = "on";pcf8574_R4.digitalWrite(P6, LOW);}
else if (header.indexOf("GET /31/off") >= 0) {relay31state = "off";pcf8574_R4.digitalWrite(P6, HIGH);}
else if (header.indexOf("GET /32/on") >= 0) {relay32state = "on";pcf8574_R4.digitalWrite(P7, LOW);}
else if (header.indexOf("GET /32/off") >= 0) {relay32state = "off";pcf8574_R4.digitalWrite(P7, HIGH);}
/* for(int i=0;i<32;i++)
relaystate[i]="on";
relay17state = "on";// state of relay1
relay18state = "on";// state of relay2
relay19state = "on";// state of relay3
relay20state = "on";// state of relay4
relay21state = "on";// state of relay5
relay22state = "on";// state of relay6
relay23state = "on";// state of relay7
relay24state = "on";// state of relay8
relay25state = "on";// state of relay9
relay26state = "on";// state of relay10
relay27state = "on";// state of relay11
relay28state = "on";// state of relay12
relay29state = "on";// state of relay13
relay30state = "on";// state of relay14
relay31state = "on";// state of relay15
relay32state = "on";// state of relay16
pcf8574_R1.digitalWrite(i,LOW);
pcf8574_R2.digitalWrite(i,LOW);
pcf8574_R3.digitalWrite(i,LOW);
pcf8574_R4.digitalWrite(i,LOW);
/*for(int i=0;i<32;i++)
relaystate[i]="off";
relay17state = "off";// state of relay1
relay18state = "off";// state of relay2
relay19state = "off";// state of relay3
relay20state = "off";// state of relay4
relay21state = "off";// state of relay5
relay22state = "off";// state of relay6
relay23state = "off";// state of relay7
relay24state = "off";// state of relay8
relay25state = "off";// state of relay9
relay26state = "off";// state of relay10
relay27state = "off";// state of relay11
relay28state = "off";// state of relay12
relay29state = "off";// state of relay13
relay30state = "off";// state of relay14
relay31state = "off";// state of relay15
relay32state = "off";// state of relay16
// Display the HTML web page
client.println("<style>html { font-family: Helvetica; display: inline-block; margin: 0px auto; text-align: center;}");
//client.println(".button { background-color: #195B6A; border: none; color: white; padding: 16px 40px;");
//client.println("text-decoration: none; font-size: 30px; margin: 2px; cursor: pointer;}");
client.println(".button { background-color: #195B10; border: none; color: white; padding: 16px 40px;");
client.println("text-decoration: none; font-size: 35px; margin: 2px; cursor: pointer;}");
if (flag_read_di==1)
client.println(" relay1:" + relay1state + " relay2:" + relay2state + " relay3:" + relay3state + " relay4:" + relay4state + " relay5:" + relay5state + " relay6:" + relay6state + " relay7:" + relay7state + " relay8:" + relay8state + " relay9:" + relay9state + " relay10:" + relay10state + " relay11:" + relay11state + " relay12:" + relay12state + " relay13:" + relay13state + " relay14:" + relay14state + " relay15:" + relay15state + " relay16:" + relay16state + " relay17:" + relay17state + " relay18:" + relay18state + " relay19:" + relay19state + " relay20:" + relay20state + " relay21:" + relay21state + " relay22:" + relay22state + " relay23:" + relay23state + " relay24:" + relay24state + " relay25:" + relay25state + " relay26:" + relay26state + " relay27:" + relay27state + " relay28:" + relay28state + " relay29:" + relay29state + " relay30:" + relay30state + " relay31:" + relay31state + " relay32:" + relay32state);
else
// Web Page Heading
client.println("<body><h1>KC868-A32 Web Server</h1>");
if (relay9state == "off") client.println("<a href=\"/9/on\"><button class=\"button\">09-OFF</button></a>"); else client.println("<a href=\"/9/off\"><button class=\"button\">09-ON </button></a>");
if (relay10state == "off") client.println("<a href=\"/10/on\"><button class=\"button\">10-OFF</button></a>"); else client.println("<a href=\"/10/off\"><button class=\"button\">10-ON</button></a>");
if (relay11state == "off") client.println("<a href=\"/11/on\"><button class=\"button\">11-OFF</button></a>"); else client.println("<a href=\"/11/off\"><button class=\"button\">11-ON</button></a>");
if (relay12state == "off") client.println("<a href=\"/12/on\"><button class=\"button\">12-OFF</button></a>"); else client.println("<a href=\"/12/off\"><button class=\"button\">12-ON</button></a>");
if (relay13state == "off") client.println("<a href=\"/13/on\"><button class=\"button\">13-OFF</button></a>"); else client.println("<a href=\"/13/off\"><button class=\"button\">13-ON</button></a>");
if (relay14state == "off") client.println("<a href=\"/14/on\"><button class=\"button\">14-OFF</button></a>"); else client.println("<a href=\"/14/off\"><button class=\"button\">14-ON</button></a>");
if (relay15state == "off") client.println("<a href=\"/15/on\"><button class=\"button\">15-OFF</button></a>"); else client.println("<a href=\"/15/off\"><button class=\"button\">15-ON</button></a>");
if (relay16state == "off") client.println("<a href=\"/16/on\"><button class=\"button\">16-OFF</button></a>"); else client.println("<a href=\"/16/off\"><button class=\"button\">16-ON</button></a>");
if (relay17state == "off") client.println("<a href=\"/17/on\"><button class=\"button\">17-OFF</button></a>"); else client.println("<a href=\"/17/off\"><button class=\"button\">17-ON</button></a>");
if (relay18state == "off") client.println("<a href=\"/18/on\"><button class=\"button\">18-OFF</button></a>"); else client.println("<a href=\"/18/off\"><button class=\"button\">18-ON</button></a>");
if (relay19state == "off") client.println("<a href=\"/19/on\"><button class=\"button\">19-OFF</button></a>"); else client.println("<a href=\"/19/off\"><button class=\"button\">19-ON</button></a>");
if (relay20state == "off") client.println("<a href=\"/20/on\"><button class=\"button\">20-OFF</button></a>"); else client.println("<a href=\"/20/off\"><button class=\"button\">20-ON</button></a>");
if (relay21state == "off") client.println("<a href=\"/21/on\"><button class=\"button\">21-OFF</button></a>"); else client.println("<a href=\"/21/off\"><button class=\"button\">21-ON</button></a>");
if (relay22state == "off") client.println("<a href=\"/22/on\"><button class=\"button\">22-OFF</button></a>"); else client.println("<a href=\"/22/off\"><button class=\"button\">22-ON</button></a>");
if (relay23state == "off") client.println("<a href=\"/23/on\"><button class=\"button\">23-OFF</button></a>"); else client.println("<a href=\"/23/off\"><button class=\"button\">23-ON</button></a>");
if (relay24state == "off") client.println("<a href=\"/24/on\"><button class=\"button\">24-OFF</button></a>"); else client.println("<a href=\"/24/off\"><button class=\"button\">24-ON</button></a>");
if (relay25state == "off") client.println("<a href=\"/25/on\"><button class=\"button\">25-OFF</button></a>"); else client.println("<a href=\"/25/off\"><button class=\"button\">25-ON</button></a>");
if (relay26state == "off") client.println("<a href=\"/26/on\"><button class=\"button\">26-OFF</button></a>"); else client.println("<a href=\"/26/off\"><button class=\"button\">26-ON</button></a>");
if (relay27state == "off") client.println("<a href=\"/27/on\"><button class=\"button\">27-OFF</button></a>"); else client.println("<a href=\"/27/off\"><button class=\"button\">27-ON</button></a>");
if (relay28state == "off") client.println("<a href=\"/28/on\"><button class=\"button\">28-OFF</button></a>"); else client.println("<a href=\"/28/off\"><button class=\"button\">28-ON</button></a>");
if (relay29state == "off") client.println("<a href=\"/29/on\"><button class=\"button\">29-OFF</button></a>"); else client.println("<a href=\"/29/off\"><button class=\"button\">29-ON</button></a>");
if (relay30state == "off") client.println("<a href=\"/30/on\"><button class=\"button\">30-OFF</button></a>"); else client.println("<a href=\"/30/off\"><button class=\"button\">30-ON</button></a>");
if (relay31state == "off") client.println("<a href=\"/31/on\"><button class=\"button\">31-OFF</button></a>"); else client.println("<a href=\"/31/off\"><button class=\"button\">31-ON</button></a>");
if (relay32state == "off") client.println("<a href=\"/32/on\"><button class=\"button\">32-OFF</button></a>"); else client.println("<a href=\"/32/off\"><button class=\"button\">32-ON</button></a>");
client.println("<a href=\"/all/on\"><button class=\"button\">all ON</button></a>");
client.println("<a href=\"/all/off\"><button class=\"button\">all OFF</button></a>");
client.println();
break;
currentLine = "";
// Clear the header variable
header = "";
// Close the connection
client.stop();
Serial.println("");
flag_read_di=0;
void ScanKey()
delay(20);
if(pcf8574_I2.digitalRead(i) == LOW) //key pressed
delay(20);
if(pcf8574_I2.digitalRead(i) == LOW) //key pressed again
pcf8574_R2.digitalWrite(i,!pcf8574_R2.digitalRead(i)); // toggle relay1 state
while(pcf8574_I2.digitalRead(i) == LOW); //wait remove hand
if (pcf8574_R2.digitalRead(i) == LOW) relaystate[i+9]="on";else relaystate[i+9]="off";
if(pcf8574_I3.digitalRead(i) == LOW) //key pressed
delay(20);
if(pcf8574_I3.digitalRead(i) == LOW) //key pressed again
pcf8574_R3.digitalWrite(i,!pcf8574_R3.digitalRead(i)); // toggle relay1 state
while(pcf8574_I3.digitalRead(i) == LOW); //wait remove hand
if (pcf8574_R3.digitalRead(i) == LOW) relaystate[i+17]="on";else relaystate[i+17]="off";
if(pcf8574_I4.digitalRead(i) == LOW) //key pressed
delay(20);
if(pcf8574_I4.digitalRead(i) == LOW) //key pressed again
pcf8574_R4.digitalWrite(i,!pcf8574_R4.digitalRead(i)); // toggle relay1 state
while(pcf8574_I4.digitalRead(i) == LOW); //wait remove hand
if (pcf8574_R4.digitalRead(i) == LOW) relaystate[i+25]="on";else relaystate[i+25]="off";
