KC868-H32B blinds motor control and connect
#11
(12-22-2022, 01:02 AM)admin Wrote: usually two relay work with one motor, now H32BS the newest firmware have added "interlock" option for motor, that is useful for motor and protect motor. make sure you can update to firmware v1.50SP. here is download link: https://www.kincony.com/forum/showthread.php?tid=2455
ok. can you send link for instructions how to update? First time doing this Blush
https://youtu.be/LLIJe9VTVq8
is there any other way instead of using RS485-USB cable?
only use by USB-RS232 cable, not RS485.
(01-20-2023, 11:35 AM)admin Wrote: only use by USB-RS232 cable, not RS485.
I have difficulties installing  USB-RS232, tried on several computers and didn't manage to install.
Is there any other way?
I have Somfy WT protect motors. Can motors be damaged if software on HS32BS not updated?
when update firmware will not control your relay output ON/OFF.
(03-13-2023, 11:00 AM)admin Wrote: when update firmware will not control your relay output ON/OFF.
Can you please clarify more detail?
You mean automatical control will not work?
If I use manual switch than it should work normally?
my means: during you update your firmware. controller's relay will not change state.
I have Somfy WT protect motors. Can motors be damaged if software on HS32BS not updated? why must update your firmware? current version also can use. i don't know what you want to do with update firmware.
(03-14-2023, 08:22 AM)admin Wrote: my means: during you update your firmware. controller's relay will not change state.
Ok, understand what you mean. Thanks for fast response.
I wanted to update firmware of HS32BS because it was advise by Kincony to update so the controller can work with blinds.
Did I understand wrong?
ok, if you want use "interlock" function, you can update.
