[Arduino IDE demo source code for KC868-A8S]--#17-A8S_Digital input_Ethernet_Web_serv
[Arduino IDE demo source code for KC868-A8S]--#17-A8S_Digital input_Ethernet_Web_server_code
.zip   KC868-A8S_Digital_input_Web_Server-ETH.zip (Size: 468.1 KB / Downloads: 1,132)
PC and phone webpage display
* Create Your own WebServer for KC868-A8s Smart Controller*
#include "PCF8574.h"
#define DEBUG_ETHERNET_WEBSERVER_PORT       Serial
// Debug Level from 0 to 4
#define _ETHERNET_WEBSERVER_LOGLEVEL_       3
WiFiServer server(80);
// Current time
// Previous time
String header;
PCF8574 pcf8574_1(0x22,4,5);
  for(int i=0;i<=7;i++)
     pcf8574_1.pinMode(i, INPUT);
    pcf8574_1.begin();
   while (!Serial);
  WT32_ETH01_onEvent();
  server.begin();
void loop(){
  WiFiClient client = server.available();   // Listen for incoming clients
    currentTime = millis();
    previousTime = currentTime;
        header += c;
           client.print(
            "HTTP/1.1 200 OK\r\n"
            "Content-Type: text/html\r\n"
            "Connection: close\r\n"  // the connection will be closed after completion of the response
            "Refresh: 2\r\n"        // refresh the page automatically every 3 sec
            "\r\n");
            client.println("<style>html { font-family: Helvetica; display: inline-block; border: 3px solid green;margin: 0px auto;text-align: center;font-size: 10px;}");
            client.println(".button { background-color: MediumSeaGreen; border-radius: 10px;color: white; padding: 10px 10px;");
            client.println(".button1 { background-color: Tomato; border-radius: 10px;color: white; padding: 10px 10px;");
            client.println(".button2 {background-color: Tomato;}</style></head>");
            client.println("<body><h1>KC868-A8S Web Server</h1>");
            if (pcf8574_1.digitalRead(0)==0) client.println("<a><button class=\"button1\">INPUT01</button></a>"); else client.println("<a><button class=\"button\">INPUT01</button></a>");
            if (pcf8574_1.digitalRead(1)==0) client.println("<a><button class=\"button1\">INPUT02</button></a>"); else client.println("<a><button class=\"button\">INPUT02</button></a>");
            if (pcf8574_1.digitalRead(2)==0) client.println("<a><button class=\"button1\">INPUT03</button></a>"); else client.println("<a><button class=\"button\">INPUT03</button></a>");
            if (pcf8574_1.digitalRead(3)==0) client.println("<a><button class=\"button1\">INPUT04</button></a>"); else client.println("<a><button class=\"button\">INPUT04</button></a>");
            if (pcf8574_1.digitalRead(4)==0) client.println("<a><button class=\"button1\">INPUT05</button></a>"); else client.println("<a><button class=\"button\">INPUT05</button></a>");
            if (pcf8574_1.digitalRead(5)==0) client.println("<a><button class=\"button1\">INPUT06</button></a>"); else client.println("<a><button class=\"button\">INPUT06</button></a>");
            if (pcf8574_1.digitalRead(6)==0) client.println("<a><button class=\"button1\">INPUT07</button></a>"); else client.println("<a><button class=\"button\">INPUT07</button></a>");
            if (pcf8574_1.digitalRead(7)==0) client.println("<a><button class=\"button1\">INPUT08</button></a>"); else client.println("<a><button class=\"button\">INPUT08</button></a>");
            client.println();
            break;
            currentLine = "";
    // Clear the header variable
    header = "";
    // Close the connection
    client.stop();
    Serial.println("");
Are there any code available where I am able set inputs as long as I push from Ethernet Web Server interface.
I would like to be able to use the web server as remote control for my written code as a parallel input (switch).
Here it only uses the read status of inputs.
if you want to remote see input state. you can use MQTT is better. or you can download "KCS" firmware .
I don't want to remote see the inputs!!!!
I want to be able to force an input HIGH or LOW remotely via the Web Server
ok, just download "KCS" firmware, then  you can monitor all input state on webpage, it already have web service.
[Image: monitor.png]
I already tried out the KCS firmware but cannot use it directly as I need my own Arduino code added for the Home Control I am working on.
Will you be able to share the source code for the KCS firmware if it is written in Arduino IDE.
sorry, "KCS" is not open source. you can write your own code, all our source code have posted in our forum.
use this code, another topic have replied you. please not post topic repeat.
