06-12-2023, 04:09 PM
Hello everyone ! Is it possible to connect a 3.3V input to one of the connectors of the module?
Digital inputs
06-12-2023, 09:59 PM
you can try, maybe 3.3v will not trigger.
06-12-2023, 10:25 PM
(06-12-2023, 09:59 PM)admin Wrote: you can try, maybe 3.3v will not trigger.Looking at the schematic from DI-1 to DI-6 they are activated with 0V since the common is +12V. But maybe you could help me if I use them in the analog inputs, I just want to know if I can make this connection, my reference voltage is 0 - 3.3 V it is the voltage of the KINCONY A6 board ... thanks in advance ..
06-12-2023, 11:51 PM
(06-12-2023, 10:25 PM)bsarevalo Wrote:(06-12-2023, 09:59 PM)admin Wrote: you can try, maybe 3.3v will not trigger.Looking at the schematic from DI-1 to DI-6 they are activated with 0V since the common is +12V. But maybe you could help me if I use them in the analog inputs, I just want to know if I can make this connection, my reference voltage is 0 - 3.3 V it is the voltage of the KINCONY A6 board ... thanks in advance .. It's solved! I just wanted an advice or opinion from the manufacturer! I have connected the analog input A1, but I have configured it as a digital input in the program! it works perfectly ! thank you !
06-13-2023, 12:10 AM
ok, good.
02-01-2026, 04:15 AM
(06-12-2023, 11:51 PM)бсаревало Wrote:(06-12-2023, 10:25 PM)бсаревало Wrote:(06-12-2023, 09:59 PM)администратор Wrote: Можете попробовать, возможно, 3,3 В не сработает.Судя по схеме, контакты DI-1–DI-6 активируются напряжением 0 В, а общий вывод — +12 В. Но, может быть, вы могли бы мне помочь с подключением их к стандартному входу? Я просто хочу узнать, можно ли восстановить такое соединение. Мое опорное напряжение составляет 0–3,3 В, это напряжение платы KINCONY A6... Заранее спасибо. Привет, можете прислать пример скетча для Arduino IDE,
02-02-2026, 01:00 AM
(02-01-2026, 04:15 AM)AlexeyAris Wrote:(06-12-2023, 11:51 PM)бсаревало Wrote:(06-12-2023, 10:25 PM)бсаревало Wrote:(06-12-2023, 09:59 PM)администратор Wrote: Можете попробовать, возможно, 3,3 В не сработает.Судя по схеме, контакты DI-1–DI-6 активируются напряжением 0 В, а общий вывод — +12 В. Но, может быть, вы могли бы мне помочь с подключением их к стандартному входу? Я просто хочу узнать, можно ли восстановить такое соединение. Мое опорное напряжение составляет 0–3,3 В, это напряжение платы KINCONY A6... Заранее спасибо. https://www.kincony.com/forum/showthread.php?tid=1865
| 2 Guest(s) |
