"KCS" v2.1.0 firmware BIN file download
v2.1.0 improment:
add support KC868-AIO board.
fixed some bugs.
add get temperature and humidity sensor by TCP, HTTP, MQTT protocol.
.zip   KCS_KC868_A4S_V2.1.0.zip (Size: 796.4 KB / Downloads: 819)
.zip   KCS_KC868_A6_V2.1.0.zip (Size: 771.37 KB / Downloads: 741)
.zip   KCS_KC868_A8_V2.1.0.zip (Size: 779.38 KB / Downloads: 893)
.zip   KCS_KC868_A8M_V2.1.0.zip (Size: 796.14 KB / Downloads: 703)
.zip   KCS_KC868_A8S_V2.1.0.zip (Size: 797.32 KB / Downloads: 727)
.zip   KCS_KC868_A16_V2.1.0.zip (Size: 786.76 KB / Downloads: 633)
.zip   KCS_KC868_A16S_V2.1.0.zip (Size: 797.71 KB / Downloads: 789)
.zip   KCS_KC868_A32_V2.1.0.zip (Size: 780.63 KB / Downloads: 825)
.zip   KCS_KC868_A32M_V2.1.0.zip (Size: 798.84 KB / Downloads: 729)
.zip   KCS_KC868_A64_V2.1.0.zip (Size: 780.56 KB / Downloads: 719)
.zip   KCS_KC868_A128_V2.1.0.zip (Size: 780.62 KB / Downloads: 674)
.zip   KCS_KC868_AG_V2.1.0.zip (Size: 759.45 KB / Downloads: 599)
.zip   KCS_KC868_AI_V2.1.0.zip (Size: 783.17 KB / Downloads: 695)
.zip   KCS_KC868_AIO_V2.1.0.zip (Size: 797.05 KB / Downloads: 842)
.zip   KCS_KC868_AK_V2.1.0.zip (Size: 762.09 KB / Downloads: 748)
.zip   KCS_KC868_AM_V2.1.0.zip (Size: 772.82 KB / Downloads: 679)
.zip   KCS_KC868_AP_V2.1.0.zip (Size: 778.84 KB / Downloads: 745)
.zip   KCS_KC868_ASR_V2.1.0.zip (Size: 750.46 KB / Downloads: 834)
.zip   KCS_KC868_E16S_V2.1.0.zip (Size: 783.2 KB / Downloads: 844)
.zip   KCS_KC868_UAIR_V2.1.0.zip (Size: 762.48 KB / Downloads: 746)
.zip   KCS_KC868_A2_V2.1.0.zip (Size: 785.48 KB / Downloads: 699)
.zip   KCS_KC868_A4_V2.1.0.zip (Size: 775.88 KB / Downloads: 864)
I just installed the KCS V2 to my KC868-AIO.
It works great!
But how can I use 1 switch to turn on/off (single click) and hold to increase/decrease the analog output?
The only thing that happens is the AO gets set to the configured value.
I tried all the different trigger options.
[Image: image.png]
you can create second IFTTT command for "HOLD ON". just create multi IFTTT command is ok.
Ok, is this behavior possible with one switch?
The light is off
single click - the light turns on to the last brightness value
single click - the light turns off
hold - the light increases in brightness
hold again - the light decreases in brightness
maybe you need multi times of "hold", you can test it.
(08-16-2023, 08:00 AM)admin Wrote: hold - the light increases in brightness
Hi Admin
Is it possible to make more "HOLD ON-s" rows.  3....5 HOLD ON
HOLD ON 1
HOLD ON 2
HOLD ON 3
At the settings menu can adjust the hold on time:
Example:
HOLD ON 1   500ms
HOLD ON 2   700ms
HOLD ON 3   900ms
This is good for dimmer.
Example:  500ms dimmer 20%, 700ms dimmer 40%; 900ms dimmer 70%
do you means, create some different HOLD ON trigger, send customsize protocol command to dimmer controller?
now "KCS" firmware not support this, but i will save your suggestion.
I tried many different things...
Currently, it is not possible to get this behavior. Even creating multiple IFTTT commands.
Will this be possible in the future?
Otherwise, the KCS system is not an option for me and I will need to use ESPHome and configure everything in home assistant.
I would prefer to use the KCS system because it works immediately after a power outage.
Thanks in advance!
your requirements suggest use ESPHome config in yaml. ESPHome also work locally.
