"KCS" v1.0.24 firmware BIN file download
#21
ok, understand, we will update "KCS" firmware, next version we can let let timer large the "255", enough for 30 minutes for you to use.
we will save your suggestion.
The latest 'KCS' v1.0.24 firmware BIN file is now available for download. Don't miss out on enhanced features and improvements. Update now for a smoother experience.
the newest KCS version is V2.2.2
where is for A32 V.1.4.
A32 or A32 Pro controller?
Will the sensor section that is in version 2.2.2 ever be added to 1.0.24?
When I add my solutions for input control in v2.2.2 using IFTTT there is to much lag. Sometimes they work, but most of the time they don't.
While v2.2.2 is nice it does not work reliably on my A16.
which sensor model you are using? what IFTTT command you have created?
I have included images from v1.0.24 which works reliably and v2.2.2 which does not.
I have also included two videos as zip files. Every time the blue light changes, the inputs and outputs should change. KCS v1.0.24 shows that is works reliably, KCS v2.2.2 shows that it misses state changes fairly regular.
.zip   KCS v1.0.24 compressed.zip (Size: 6.57 MB / Downloads: 633)
.zip   KCS v2.2.2 Compressed.zip (Size: 8.06 MB / Downloads: 622)
do you have enabled many different protocol? if YES, disable unused protocol , have a test.
