Threads: 1,529
11-10-2021, 02:17 AM
(This post was last modified: 11-29-2021, 01:37 AM by admin.)
platform: ESP32
board: esp32dev
output:
- platform: esp32_dac
pin: GPIO25
pin: GPIO26
light:
- platform: monochromatic
output: dac_output1
gamma_correct: 2
output: dac_output2
ota:
password: "3b853165e19b67ba8193c59fe59f21a7"
wifi:
ssid: "KinCony"
password: "a12345678"
ap:
ssid: "Kc868-A4 Fallback Hotspot"
password: "RgIGz8qo4bVC"
captive_portal:
Threads: 0
Hi Admins,
I use KC868-A4 with esphome.
I have problem with DAC output, in my case is to low. Max i have 9.45V. But i need 9.8V minimum. What i can do in my problem
Threads: 1,529
what's your power supply voltage?
Threads: 0
So any idea? Why can't get 10V ?
On your video about DAC is 9,5V. It's max?
Threads: 1,529
1. you can check your PCB 3.3v Vcc pin whether is well. whether it's 3.3v value.
now R37,R38,R47,R49 all are 10K resistance.
if use 20K resistance , MAX DAC voltage should be: 3.3v * (1 + 20K/10K) = 9.9V
2. if Vcc is 3.3v work well , you can try to replace 20K resistance to 22K for a test. it should be output MAX 10.05V
Threads: 1,529
Which is one the Vcc pin? that is 5V , see text on the PCB.
And where i should put the 20k or 22k resistance? R37,R38,R47,R49
Threads: 0
08-12-2023, 06:19 PM
(This post was last modified: 08-12-2023, 06:20 PM by rtoivo.)
I'm using node red in home assistant.
I have tried several various ways to control DAC (percentage value) from node red without success.
Output is working fine in lovelace.
Could you show an example how control should be done in node red?
Threads: 1,529
which board you are using? if use KC868-A4 board, i think you can download "KCS" v2 firmware, then integrate to Node-Red by MQTT.
