KC868 A4 - Help In Program
I wanted to know if you can help me with a programming, I'm using the digital inputs to connect the relays 1 - 4, but I wanted to know if I can change the state of an alexa device with a digital input (ex: led driver)
what's your means? can you draw a photo, what do you want to do?
The programming will be attached, for understanding, I am using the digital inputs in parallel with the alexa to activate the output relays, but when I activate the digital input, the relay activates, but in the devices it does not appear as on, I wanted to see if it is possible to make this switch.
.zip   Casa_A4_Digital_Com_Wifi.zip (Size: 1.55 KB / Downloads: 570)
i see. why you write arduino code directly support to use Alexa speaker? we have video tour:
https://youtu.be/s7JJE5pORcc
