KC868-H32B template XML file for Loxone home automation
Anybody interested in using the KC868-H32B with Loxone, has to select "Virtual Outputs" and import this template. After this file is imported only the IP address as per user's ip address has to be give. There is no need to configure all the 32 relays for ON and OFF commands.
Thanks for Mr wilson from Kuwait shared this config file.
.zip   VO_KC868-H32B.zip (Size: 710 bytes / Downloads: 613)
Hi,
I've fixed your template (because the uploaded one has only 16 configured outputs and 10 invalid outputs).
Also added templates to H16B, H8B, H4B and H2B.
Also added RS232 templates which supports the inputs, too.
Note: It shoud be copied to the appropriate subfolder of the Loxone templates folder, so
RS232 templates to:
C:\Users\username\Documents\Loxone\Loxone Config\Templates\Comm
Virtual Output / HTTP templates to:
C:\Users\{username}\Documents\Loxone\Loxone Config\Templates\VirtualOut
Otherwise (the latest) Loxone Config can't import it.
And as it already mentioned the IP address of the KinCony relay should be set.
You should also change "post password". Personally I recommend to search and replace in the tempate xml file. Much faster than one by one in Loxone Config after importong the template.
When somebody interested in it, I can add the TCP (without HTTP) and MQTT Virtual Output templates, too.
.zip   Templates.zip (Size: 6.59 KB / Downloads: 530)
thank you very much.
