Lesson12 - integrate KC868-Uair to home assistant to monitor temperature & humidity
1. To enable the USB 2.0 ports on the raspberry pi 4 Compute Module 4, you need to edit the boot config file (/boot/config.txt) and add:
dtoverlay=dwc2,dr_mode=host
2. enable home assistant "Advanced Mode"
3. install ESPHome in Add-ons
4. config KC868-Uair
KC868-Uair document:
KC868-Uair ESP32 I/O pin define: https://www.kincony.com/forum/showthread.php?tid=1438
ESPHome configure for KC868-Uair:
  platform: ESP32
  board: esp32dev
ota:
  password: "978e66f878ed5041b830cfb427393c79"
wifi:
  ssid: "KinCony"  # your wifi router ssid
  password: "12345678"  # your wifi password
  ap:
    ssid: "Kc868-Uair Fallback Hotspot"
    password: "FbTxCLlbDvbO"
captive_portal:
# follow configure use for DS18B20 temperature sensor, SHT30 temperature and humidity sensor. WS2812B RGB LEDs.
  sda: 4
  scl: 16
# Example configuration entry
dallas:
  - pin: GPIO27
    update_interval: 15s
# Individual sensors
  - platform: dallas
    address: 0xC000000004D81528  # your DS18B20 address
    name: "internal Temperature"
  - platform: sht3xd
    temperature:
      name: "extend Temperature"
    humidity:
      name: "extend Humidity"
    address: 0x44
light:
  - platform: fastled_clockless
    chipset: WS2812B
    pin: GPIO32    # Pin Define connected with LED strip
    num_leds: 4  #LEDs number
    rgb_order: GRB
    effects:
      - addressable_rainbow:        ##defined 7 effects styles
      - addressable_color_wipe:
      - addressable_scan:
      - addressable_twinkle:
      - addressable_random_twinkle:
      - addressable_fireworks:
      - addressable_flicker:
    chipset: WS2812B
    pin: GPIO33    # Pin Define connected with LED strip
    num_leds: 1  #LEDs number
    rgb_order: RGB
    effects:
      - addressable_scan:
.txt   Made_for_ESPHome_KC868-Uair.txt (Size: 1.97 KB / Downloads: 642)
