04-08-2022, 11:45 AM
You just need to select "Virtual Outputs" and import this template. After this file is imported only the IP address as per user's ip address has to be give. There is no need to configure all the 32 relays for ON and OFF commands.
VO_KC868-H32B.zip (Size: 710 bytes / Downloads: 687)
