KC868-A64 configure for ESPhome
  platform: ESP32
  board: esp32dev
# Example configuration entry
  - id: bus_a
    sda: 5
    scl: 16
    frequency: 400kHz
  - id: bus_b
    sda: 15
    scl: 4
    frequency: 400kHz
  type: LAN8720
  mdc_pin: GPIO23
  mdio_pin: GPIO18
  clk_mode: GPIO17_OUT
  phy_addr: 0
  # Optional manual IP
  manual_ip:
    static_ip: 192.168.1.198
    gateway: 192.168.1.1
    subnet: 255.255.255.0
pcf8574:
  - id: 'pcf8574_hub_out_1'  # for output channel 1-16
    i2c_id: bus_a
    address: 0x24
    pcf8575: true
  - id: 'pcf8574_hub_out_2'  # for output channel 17-32
    i2c_id: bus_a
    address: 0x25
    pcf8575: true
  - id: 'pcf8574_hub_out_3'  # for output channel 33-48
    i2c_id: bus_a
    address: 0x21
    pcf8575: true
  - id: 'pcf8574_hub_out_4'  # for output channel 49-64
    i2c_id: bus_a
    address: 0x22
    pcf8575: true
  - id: 'pcf8574_hub_in_1'  # for a64--input channel 1-16
    i2c_id: bus_b
    address: 0x24
    pcf8575: true
  - id: 'pcf8574_hub_in_2'  # for a64--input channel 17-32
    i2c_id: bus_b
    address: 0x25
    pcf8575: true
  - id: 'pcf8574_hub_in_3'  # for a64--input channel 33-48
    i2c_id: bus_b
    address: 0x21
    pcf8575: true
  - id: 'pcf8574_hub_in_4'  # for a64--input channel 49-64
    i2c_id: bus_b
    address: 0x22
    pcf8575: true
# Individual outputs
      pcf8574: pcf8574_hub_out_1
      mode: OUTPUT
      number: 1
      mode: OUTPUT
      number: 2
      mode: OUTPUT
      number: 3
      mode: OUTPUT
      number: 4
      mode: OUTPUT
      number: 5
      mode: OUTPUT
      number: 6
      mode: OUTPUT
      number: 7
      mode: OUTPUT
      number: 8
      mode: OUTPUT
      number: 9
      mode: OUTPUT
      number: 10
      mode: OUTPUT
      number: 11
      mode: OUTPUT
      number: 12
      mode: OUTPUT
      number: 13
      mode: OUTPUT
      number: 14
      mode: OUTPUT
      number: 15
      mode: OUTPUT
      pcf8574: pcf8574_hub_out_2
      mode: OUTPUT
      number: 1
      mode: OUTPUT
      number: 2
      mode: OUTPUT
      number: 3
      mode: OUTPUT
      number: 4
      mode: OUTPUT
      number: 5
      mode: OUTPUT
      number: 6
      mode: OUTPUT
      number: 7
      mode: OUTPUT
      number: 8
      mode: OUTPUT
      number: 9
      mode: OUTPUT
      number: 10
      mode: OUTPUT
      number: 11
      mode: OUTPUT
      number: 12
      mode: OUTPUT
      number: 13
      mode: OUTPUT
      number: 14
      mode: OUTPUT
      number: 15
      mode: OUTPUT
      pcf8574: pcf8574_hub_out_3
      mode: OUTPUT
      number: 1
      mode: OUTPUT
      number: 2
      mode: OUTPUT
      number: 3
      mode: OUTPUT
      number: 4
      mode: OUTPUT
      number: 5
      mode: OUTPUT
      number: 6
      mode: OUTPUT
      number: 7
      mode: OUTPUT
      number: 8
      mode: OUTPUT
      number: 9
      mode: OUTPUT
      number: 10
      mode: OUTPUT
      number: 11
      mode: OUTPUT
      number: 12
      mode: OUTPUT
      number: 13
      mode: OUTPUT
      number: 14
      mode: OUTPUT
      number: 15
      mode: OUTPUT
      pcf8574: pcf8574_hub_out_4
      mode: OUTPUT
      number: 1
      mode: OUTPUT
      number: 2
      mode: OUTPUT
      number: 3
      mode: OUTPUT
      number: 4
      mode: OUTPUT
      number: 5
      mode: OUTPUT
      number: 6
      mode: OUTPUT
      number: 7
      mode: OUTPUT
      number: 8
      mode: OUTPUT
      number: 9
      mode: OUTPUT
      number: 10
      mode: OUTPUT
      number: 11
      mode: OUTPUT
      number: 12
      mode: OUTPUT
      number: 13
      mode: OUTPUT
      number: 14
      mode: OUTPUT
      number: 15
      mode: OUTPUT
# Individual inputs
      pcf8574: pcf8574_hub_in_1
      mode: INPUT
      number: 1
      mode: INPUT
      number: 2
      mode: INPUT
      number: 3
      mode: INPUT
      number: 4
      mode: INPUT
      number: 5
      mode: INPUT
      number: 6
      mode: INPUT
      number: 7
      mode: INPUT
      number: 8
      mode: INPUT
      number: 9
      mode: INPUT
      number: 10
      mode: INPUT
      number: 11
      mode: INPUT
      number: 12
      mode: INPUT
      number: 13
      mode: INPUT
      number: 14
      mode: INPUT
      number: 15
      mode: INPUT
      pcf8574: pcf8574_hub_in_2
      mode: INPUT
      number: 1
      mode: INPUT
      number: 2
      mode: INPUT
      number: 3
      mode: INPUT
      number: 4
      mode: INPUT
      number: 5
      mode: INPUT
      number: 6
      mode: INPUT
      number: 7
      mode: INPUT
      number: 8
      mode: INPUT
      number: 9
      mode: INPUT
      number: 10
      mode: INPUT
      number: 11
      mode: INPUT
      number: 12
      mode: INPUT
      number: 13
      mode: INPUT
      number: 14
      mode: INPUT
      number: 15
      mode: INPUT
      pcf8574: pcf8574_hub_in_3
      mode: INPUT
      number: 1
      mode: INPUT
      number: 2
      mode: INPUT
      number: 3
      mode: INPUT
      number: 4
      mode: INPUT
      number: 5
      mode: INPUT
      number: 6
      mode: INPUT
      number: 7
      mode: INPUT
      number: 8
      mode: INPUT
      number: 9
      mode: INPUT
      number: 10
      mode: INPUT
      number: 11
      mode: INPUT
      number: 12
      mode: INPUT
      number: 13
      mode: INPUT
      number: 14
      mode: INPUT
      number: 15
      mode: INPUT
      pcf8574: pcf8574_hub_in_4
      mode: INPUT
      number: 1
      mode: INPUT
      number: 2
      mode: INPUT
      number: 3
      mode: INPUT
      number: 4
      mode: INPUT
      number: 5
      mode: INPUT
      number: 6
      mode: INPUT
      number: 7
      mode: INPUT
      number: 8
      mode: INPUT
      number: 9
      mode: INPUT
      number: 10
      mode: INPUT
      number: 11
      mode: INPUT
      number: 12
      mode: INPUT
      number: 13
      mode: INPUT
      number: 14
      mode: INPUT
      number: 15
      mode: INPUT
  - platform: adc
    pin: 39
    update_interval: 20s
    attenuation: 11db
  - platform: adc
    pin: 34
    attenuation: 11db
  - platform: adc
    pin: 36
    attenuation: 11db
  - platform: adc
    pin: 35
    attenuation: 11db
.txt   KC868-A64-ESPHome_PCF8575_Analog.txt (Size: 21.08 KB / Downloads: 773)
Hi all,
I am having an issue with this board.
I configured ESPHome as per your instruction but one PCF8575TS (address 0x25) corresponding to outputs 17-32 is not working properly.
All other PCF8575TS are perfectly working.
I checked voltage on pin A0, A1 and A2 of PCF8575TS (according data sheet these pins are defining the address) and everything is correct (A0 3.3V, A1 GND, A2 3.3V).
ESPHome log says:
[11:48:35][C][pcf8574:021]: PCF8574:
[11:48:35][C][pcf8574:022]: Address: 0x24
[11:48:35][C][pcf8574:023]: Is PCF8575: YES
[11:48:35][C][pcf8574:022]: Address: 0x25
[11:48:36][C][pcf8574:023]: Is PCF8575: YES
[11:48:36][E][pcf8574:025]: Communication with PCF8574 failed!
[11:48:36][C][pcf8574:021]: PCF8574:
[11:48:36][C][pcf8574:022]: Address: 0x21
[11:48:36][C][pcf8574:022]: Address: 0x22
[11:48:36][C][pcf8574:022]: Address: 0x24
[11:48:36][C][pcf8574:022]: Address: 0x25
It seems a failure of PCF8575TS chip.
Can you please confirm?
Thank you
check your esphome LOG, it will scan all I2C bus device address and output in LOG. whether one of PCF8575 address is wrong.
(03-18-2023, 12:24 PM)admin Wrote: check your esphome LOG, it will scan all I2C bus device address and output in LOG. whether one of PCF8575 address is wrong.
Hi,
I posted the  esphome LOG.
address 0x25 is correct since I verified it with voltage levels on pins A0, A1, A2 of  PCF8575.
It seems a failure of PCF8575 (infact after boot all I/Os of that specific IC are high, as described on  PCF8575 datasheet... it seems there is no communication).
Thank you
Marcello
at begin of ESPHome LOG , after work begin with IIC, that will showed all scaned IIC address. check here, whether address is not 0x25.
Which type of connector is use for extend i2c and serial?
Can you give aliexpress url please?
just use 2.54mm connector.
What pins are used for modbas?
RS485 use modbus.
The ESPHome config above could use a refresh, here are some things I addressed while setting one of these boards up this week:
  1. The names of the first 9 inputs/outputs I prefixed the numbers with '0' so they order correctly in home assistant and other places
  2. I changed to using underscores which are more compatible with HA and ESPHome (for scripting)
  3. I added "id: " to each input/output. The "name" works great for HomeAssistant, but if you want to program actions directly in the ESP program, you'll need the "id" values instead
  4. The "attenuation" value changed; it has no real effect (according to the ESPHome change logs) just prevents a warning from showing up
  5. Some of the intro generic stuff (like platform, board, etc) has been updated to follow current ESPHome practices
You can find the updated file here: https://gist.github.com/chuyskywalker/82...d099e0592e
And the diff from the above thread: https://gist.github.com/chuyskywalker/82.../revisions
And posted here as well -- (edit: nm, can't post, too long) -- (double edit: attached)
.txt   esphome-kc858-a64.yaml.txt (Size: 22.44 KB / Downloads: 328)
