[Arduino IDE demo source code for KC868-A64]--#02-LAN8720_UDP_code
Bug
/*www.kincony.com*/
/*KC868-A64 code of LAN8720 */
#include <ETH.h>
#include <WiFiUdp.h>
#define ETH_ADDR        0
#define ETH_POWER_PIN  -1
#define ETH_MDC_PIN    23
#define ETH_MDIO_PIN   18
#define ETH_TYPE       ETH_PHY_LAN8720
#define ETH_CLK_MODE   ETH_CLOCK_GPIO17_OUT
void setup()
  Serial.println();
  Serial.println("Connected");
  Serial.print("IP Address:");
void loop()
  if (packetSize)                     //if have received data
    char buf[packetSize];
    Serial.println();
    Serial.print("Received: ");
    Serial.println(buf);
    Serial.print("From IP: ");
    Serial.print("From Port: ");
    Udp.print("Received: ");
.zip   KC868-A64-LAN8720.zip (Size: 1.29 KB / Downloads: 719)
.zip   NetAssist.zip (Size: 481.86 KB / Downloads: 682)
