[Arduino IDE demo source code for KC868-E16S]--#05-KC868-E16S-LAN8720_UDP
Thumbs Up
/*www.kincony.com */
/* KC868-E16S CODE OF LAN8720-UDP */
#include <ETH.h>
#include <WiFiUdp.h>
#define ETH_ADDR        0
#define ETH_POWER_PIN  -1
#define ETH_MDC_PIN    23
#define ETH_MDIO_PIN   18
void setup()
  Serial.println();
  Serial.println("Connected");
  Serial.print("IP Address:");
void loop()
    char buf[packetSize];
    Serial.println();
    Serial.print("Received: ");
    Serial.println(buf);
    Serial.print("From IP: ");
    Serial.print("From Port: ");
    Udp.print("Received: ");
.zip   KC868-E16S-LAN8720_UDP.zip (Size: 1.11 KB / Downloads: 608)
