KC868-A8S hotel room demo configure for ESPhome
  platform: ESP32
  board: esp32dev
remote_receiver:
  pin: 16
  dump:
    - rc_switch
  tolerance: 50%
  filter: 250us
  idle: 2ms
  buffer_size: 2kb
  sda: 4
  scl: 5
# Example configuration entry
  type: LAN8720
  mdc_pin: GPIO23
  mdio_pin: GPIO18
  clk_mode: GPIO17_OUT
  phy_addr: 0
  # Optional manual IP
  manual_ip:
    static_ip: 192.168.1.199
    gateway: 192.168.1.1
    subnet: 255.255.255.0
pcf8574:
    address: 0x24
    address: 0x22
# Individual outputs
      pcf8574: pcf8574_hub_out_1
      mode: OUTPUT
      number: 1
      mode: OUTPUT
      number: 2
      mode: OUTPUT
      number: 3
      mode: OUTPUT
    interlock: [relay6]
      number: 4
      mode: OUTPUT
    interlock: [relay5]
      number: 5
      mode: OUTPUT
    interlock: [relay8]
      number: 6
      mode: OUTPUT
    interlock: [relay7]
      number: 7
      mode: OUTPUT
    on_press:
      then:
        - switch.toggle: light1
      pcf8574: pcf8574_hub_in_1
      mode: INPUT
    on_press:
      then:
        - switch.toggle: light2
      number: 1
      mode: INPUT
    on_press:
      then:
        - switch.toggle: light3
      number: 2
      mode: INPUT
    on_press:
      then:
        - switch.toggle: light4
      number: 3
      mode: INPUT
    on_press:
      then:
        - switch.toggle: relay5
      number: 4
      mode: INPUT
    on_press:
      then:
        - switch.toggle: relay6
      number: 5
      mode: INPUT
    on_press:
      then:
        - switch.toggle: relay7
      number: 6
      mode: INPUT
    on_press:
      then:
        - switch.toggle: relay8
      number: 7
      mode: INPUT
  - platform: remote_receiver
    rc_switch_raw:
      code: '001111010111001010111000'
      protocol: 1
    on_press:
      then:
    filters:
      - delayed_off: 200ms
    rc_switch_raw:
      code: '001111010111001010111100'
      protocol: 1
    on_press:
      then:
    filters:
    rc_switch_raw:
      code: '001111010111001010110100'
      protocol: 1
    on_press:
      then:
    filters:
    rc_switch_raw:
      code: '001111010111001010111001'
      protocol: 1
    on_press:
      then:
    filters:
    rc_switch_raw:
      code: '001111010111001010110010'
      protocol: 1
    on_press:
      then:
    filters:
    rc_switch_raw:
      code: '001111010111001010110101'
      protocol: 1
    on_press:
      then:
    filters:
    rc_switch_raw:
      code: '001111010111001010110001'
      protocol: 1
    on_press:
      then:
    filters:
    rc_switch_raw:
      code: '001111010111001010110011'
      protocol: 1
    on_press:
      then:
    filters:
    pin: 14
    device_class: motion
    on_release:
      - script.execute: motion_timer
script:
  - id: motion_timer
    mode: restart
    then:
      - delay: 10s
      - switch.turn_off: light1
      - switch.turn_off: light2
      - switch.turn_off: light3
      - switch.turn_off: light4
.txt   KC868-A8S-ha-config.txt (Size: 6.11 KB / Downloads: 886)
Thanks for example. Is working.
Is possible add example for AD inputs? I need to show the state of AD inputs (0-5V) in Home Assistant.
And if possible also the procedure for controlling RGBW LEDs from HA
Thanks.
- platform: adc
pin: 36
update_interval: 10s
attenuation: 11db
- platform: adc
pin: 39
attenuation: 11db
- platform: adc
pin: 34
attenuation: 11db
- platform: adc
pin: 35
attenuation: 11db
Is it possible to add an example for measuring 4-20mA on AI 3-4? Is it possible to connect a 24V sensor to this input? Thanks
esphome config line as same as measuring dc 0-5v sensor. if you connect with 4-20mA signal to board, also will convert "current" to "voltage" value.
now board input level MAX is dc12v , if you want to use 24v sensor, you can convert to dc12v then connect to digital input port.
Can you maby assist me how to connect a 4-20ma pressure sensor to the unit?
Sensor info
Supply 9-36vdc
Output 4-20ma
Range 0-5bar
the default circuit is use for analog input 0-5v. if you want to test with 4-20mA, need replace two resistance value. such as here is sample of ADC1, replace R70=0 ohm R72=150 ohm
Sso for the A6 model all Analogue inputs are 0-5v defaut. can I replace all 4 inputs reaiators to use 4 x 4-20ma sensors?
yes, you are right.
Do you have models that can use 4-20ma sensors without modifications
