home assistant RC 2022.6 mqtt config update for configuration.yaml
home assistant MQTT breaking changes RC 2022.6
before MQTT config format:
  - platform: mqtt
    unique_id: relay11
    state_topic: 'relay32/80f9caa4068e78059e31c622/state'
    command_topic: 'relay32/80f9caa4068e78059e31c622/set'
    state_on: 1
    state_off: 0
new MQTT config format:
mqtt:
  - name: 'relay11'
    unique_id: relay11
    state_on: 1
    state_off: 0
new MQTT config for two switches format:
mqtt:
  - name: 'relay11'
    unique_id: relay11
    state_on: 1
    state_off: 0
  - name: 'relay22'
    unique_id: relay22
    payload_on: '{"relay2":{"on":1}}'
    payload_off: '{"relay2":{"on":0}}'
    value_template: '{{ value_json.relay2.on }}'
    state_on: 1
    state_off: 0
.txt   before.txt (Size: 354 bytes / Downloads: 775)
.txt   now-2-switches.txt (Size: 695 bytes / Downloads: 796)
.txt   now.txt (Size: 352 bytes / Downloads: 801)
Please Let me know why mqtt config update like this?
1. What is difference? before and after?
2. If not. It has any problem?
I have already updated V.4.44 and attached RC snubber. But Sometimes mqtt in KC868-h32b has no response until reboot.
Thank you.
home assistant RC 2022.6 version need this, at 2022.9 version will stop use old mqtt format. details see: https://www.home-assistant.io/blog/2022/...ase-20226/
(06-29-2022, 08:06 AM)heyheyhey Wrote: Please Let me know why mqtt config update like this?
Thank you.
maybe your home assistant have automatic updated new version?
(06-29-2022, 11:43 AM)admin Wrote: home assistant RC 2022.6 version need this, at 2022.9 version will stop use old mqtt format. details see: https://www.home-assistant.io/blog/2022/...ase-20226/
Thanks for your very fast feedback! It was very helpful!
you are welcome.
Is there a change in binary_sensorsyntax?
- platform: mqtt
unique_id: H32B-input1
state_topic: 'relay32/3dfd899b71b9d0bbad4f5a9d12345/state'
value_template: '{{ value_json.input1.on }}'
payload_on: 1
payload_off: 0
yes, also is changed syntax.
(09-09-2022, 12:21 PM)admin Wrote: yes, also is changed syntax.
If like thses ?
mqtt:
  - name: 'H32B-input1'
    state_topic: 'relay32/xxxxxxxxxxxxxxxxxxxxxx/state'
    value_template: '{{ value_json.input6.on }}'
    payload_on: 1
    payload_off: 0
Please review the formula in the attachment, and if there is an error, please correct it
.txt   config h32b mqtt .yaml.txt (Size: 12.01 KB / Downloads: 774)
do you have tested output with new config file, work well?
now you only have problem with input mqtt syntax?
