Threads: 1
Is it possible to use terminal switches as digital inputs?
I was not interested in that they were tied to the relay outputs, I wanted to assign them the outputs in nodered.
thanks
Threads: 1,204
if your Node-Red is installed on raspberry pi. ok, no problem, let your switch terminal board connect to PI by USB port (use a usb rs232 adapter), then you can get the message that any key pressed by Node-Red.
Threads: 1
I can send kc868 through rs232 but when I connect to the terminal switch I get no response ... what am I doing wrong?
thanks
Threads: 1,204
check your pin define, use RS232's pin2,pin3,pin5, maybe you need exchange the pin2 and pin3.
Threads: 1,204
can you take a photo , how you wire.
