Threads: 13
Hi, using COL daily to manage the whole house, I am noticing things that are annoying in the long run. every time I connect it starts with F as degrees reading and not C as I would like. with IFTTT when I program the "IF" condition and select the temperature sensor, I cannot put values with commas. for example I would like to put 20.5 ° C but ", 5" it is not possible to insert it. or 20 or 21. I buffered using the conversion to F and entered 69 but I don't think a solution .. thank you!
Threads: 1,546
1. we will update COL PC software to remember "F" and "C" temperature setting in furture.
2. do you country use "," for decimal number? not use "." ?
Threads: 13
1-ok thanks!
2-we use "," however if I write for example "20," or "20." after it does not allow me to add any decimal numbers.
Threads: 1,546
2- OK, we will check when we have time, because these days in China is during new year holidays.
Threads: 13
Hi,
thank you very much, this update has fully solved the small problems of this post; )
