KC868-A128-ESPHome_PCF8575_Analog.txt (Size: 40.53 KB / Downloads: 955)
platform: ESP32
board: esp32dev
# Example configuration entry
- id: bus_a
sda: 5
scl: 16
frequency: 400kHz
- id: bus_b
sda: 15
scl: 4
frequency: 400kHz
type: LAN8720
mdc_pin: GPIO23
mdio_pin: GPIO18
clk_mode: GPIO17_OUT
phy_addr: 0
# Optional manual IP
manual_ip:
static_ip: 192.168.1.198
gateway: 192.168.1.1
subnet: 255.255.255.0
pcf8574:
- id: 'pcf8574_hub_out_1' # for output channel 1-16
i2c_id: bus_a
address: 0x24
pcf8575: true
- id: 'pcf8574_hub_out_2' # for output channel 17-32
i2c_id: bus_a
address: 0x25
pcf8575: true
- id: 'pcf8574_hub_out_3' # for output channel 33-48
i2c_id: bus_a
address: 0x21
pcf8575: true
- id: 'pcf8574_hub_out_4' # for output channel 49-64
i2c_id: bus_a
address: 0x22
pcf8575: true
- id: 'pcf8574_hub_out_5' # for output channel 65-80
i2c_id: bus_a
address: 0x26
pcf8575: true
- id: 'pcf8574_hub_out_6' # for output channel 81-96
i2c_id: bus_a
address: 0x27
pcf8575: true
- id: 'pcf8574_hub_out_7' # for output channel 97-112
i2c_id: bus_a
address: 0x20
pcf8575: true
- id: 'pcf8574_hub_out_8' # for output channel 113-128
i2c_id: bus_a
address: 0x23
pcf8575: true
- id: 'pcf8574_hub_in_1' # for a128-input channel 1-16
i2c_id: bus_b
address: 0x24
pcf8575: true
- id: 'pcf8574_hub_in_2' # for a128-input channel 17-32
i2c_id: bus_b
address: 0x25
pcf8575: true
- id: 'pcf8574_hub_in_3' # for a128-input channel 33-48
i2c_id: bus_b
address: 0x21
pcf8575: true
- id: 'pcf8574_hub_in_4' # for a128-input channel 49-64
i2c_id: bus_b
address: 0x22
pcf8575: true
- id: 'pcf8574_hub_in_5' # for a128-input channel 65-80
i2c_id: bus_b
address: 0x26
pcf8575: true
- id: 'pcf8574_hub_in_6' # for a128-input channel 81-96
i2c_id: bus_b
address: 0x27
pcf8575: true
- id: 'pcf8574_hub_in_7' # for a128-input channel 97-112
i2c_id: bus_b
address: 0x20
pcf8575: true
- id: 'pcf8574_hub_in_8' # for a128-input channel 113-128
i2c_id: bus_b
address: 0x23
pcf8575: true
# Individual outputs
pcf8574: pcf8574_hub_out_1
mode: OUTPUT
number: 1
mode: OUTPUT
number: 2
mode: OUTPUT
number: 3
mode: OUTPUT
number: 4
mode: OUTPUT
number: 5
mode: OUTPUT
number: 6
mode: OUTPUT
number: 7
mode: OUTPUT
number: 8
mode: OUTPUT
number: 9
mode: OUTPUT
number: 10
mode: OUTPUT
number: 11
mode: OUTPUT
number: 12
mode: OUTPUT
number: 13
mode: OUTPUT
number: 14
mode: OUTPUT
number: 15
mode: OUTPUT
pcf8574: pcf8574_hub_out_2
mode: OUTPUT
number: 1
mode: OUTPUT
number: 2
mode: OUTPUT
number: 3
mode: OUTPUT
number: 4
mode: OUTPUT
number: 5
mode: OUTPUT
number: 6
mode: OUTPUT
number: 7
mode: OUTPUT
number: 8
mode: OUTPUT
number: 9
mode: OUTPUT
number: 10
mode: OUTPUT
number: 11
mode: OUTPUT
number: 12
mode: OUTPUT
number: 13
mode: OUTPUT
number: 14
mode: OUTPUT
number: 15
mode: OUTPUT
pcf8574: pcf8574_hub_out_3
mode: OUTPUT
number: 1
mode: OUTPUT
number: 2
mode: OUTPUT
number: 3
mode: OUTPUT
number: 4
mode: OUTPUT
number: 5
mode: OUTPUT
number: 6
mode: OUTPUT
number: 7
mode: OUTPUT
number: 8
mode: OUTPUT
number: 9
mode: OUTPUT
number: 10
mode: OUTPUT
number: 11
mode: OUTPUT
number: 12
mode: OUTPUT
number: 13
mode: OUTPUT
number: 14
mode: OUTPUT
number: 15
mode: OUTPUT
pcf8574: pcf8574_hub_out_4
mode: OUTPUT
number: 1
mode: OUTPUT
number: 2
mode: OUTPUT
number: 3
mode: OUTPUT
number: 4
mode: OUTPUT
number: 5
mode: OUTPUT
number: 6
mode: OUTPUT
number: 7
mode: OUTPUT
number: 8
mode: OUTPUT
number: 9
mode: OUTPUT
number: 10
mode: OUTPUT
number: 11
mode: OUTPUT
number: 12
mode: OUTPUT
number: 13
mode: OUTPUT
number: 14
mode: OUTPUT
number: 15
mode: OUTPUT
pcf8574: pcf8574_hub_out_5
mode: OUTPUT
number: 1
mode: OUTPUT
number: 2
mode: OUTPUT
number: 3
mode: OUTPUT
number: 4
mode: OUTPUT
number: 5
mode: OUTPUT
number: 6
mode: OUTPUT
number: 7
mode: OUTPUT
number: 8
mode: OUTPUT
number: 9
mode: OUTPUT
number: 10
mode: OUTPUT
number: 11
mode: OUTPUT
number: 12
mode: OUTPUT
number: 13
mode: OUTPUT
number: 14
mode: OUTPUT
number: 15
mode: OUTPUT
pcf8574: pcf8574_hub_out_6
mode: OUTPUT
number: 1
mode: OUTPUT
number: 2
mode: OUTPUT
number: 3
mode: OUTPUT
number: 4
mode: OUTPUT
number: 5
mode: OUTPUT
number: 6
mode: OUTPUT
number: 7
mode: OUTPUT
number: 8
mode: OUTPUT
number: 9
mode: OUTPUT
number: 10
mode: OUTPUT
number: 11
mode: OUTPUT
number: 12
mode: OUTPUT
number: 13
mode: OUTPUT
number: 14
mode: OUTPUT
number: 15
mode: OUTPUT
pcf8574: pcf8574_hub_out_7
mode: OUTPUT
number: 1
mode: OUTPUT
number: 2
mode: OUTPUT
number: 3
mode: OUTPUT
number: 4
mode: OUTPUT
number: 5
mode: OUTPUT
number: 6
mode: OUTPUT
number: 7
mode: OUTPUT
number: 8
mode: OUTPUT
number: 9
mode: OUTPUT
number: 10
mode: OUTPUT
number: 11
mode: OUTPUT
number: 12
mode: OUTPUT
number: 13
mode: OUTPUT
number: 14
mode: OUTPUT
number: 15
mode: OUTPUT
pcf8574: pcf8574_hub_out_8
mode: OUTPUT
number: 1
mode: OUTPUT
number: 2
mode: OUTPUT
number: 3
mode: OUTPUT
number: 4
mode: OUTPUT
number: 5
mode: OUTPUT
number: 6
mode: OUTPUT
number: 7
mode: OUTPUT
number: 8
mode: OUTPUT
number: 9
mode: OUTPUT
number: 10
mode: OUTPUT
number: 11
mode: OUTPUT
number: 12
mode: OUTPUT
number: 13
mode: OUTPUT
number: 14
mode: OUTPUT
number: 15
mode: OUTPUT
# Individual inputs
pcf8574: pcf8574_hub_in_1
mode: INPUT
number: 1
mode: INPUT
number: 2
mode: INPUT
number: 3
mode: INPUT
number: 4
mode: INPUT
number: 5
mode: INPUT
number: 6
mode: INPUT
number: 7
mode: INPUT
number: 8
mode: INPUT
number: 9
mode: INPUT
number: 10
mode: INPUT
number: 11
mode: INPUT
number: 12
mode: INPUT
number: 13
mode: INPUT
number: 14
mode: INPUT
number: 15
mode: INPUT
pcf8574: pcf8574_hub_in_2
mode: INPUT
number: 1
mode: INPUT
number: 2
mode: INPUT
number: 3
mode: INPUT
number: 4
mode: INPUT
number: 5
mode: INPUT
number: 6
mode: INPUT
number: 7
mode: INPUT
number: 8
mode: INPUT
number: 9
mode: INPUT
number: 10
mode: INPUT
number: 11
mode: INPUT
number: 12
mode: INPUT
number: 13
mode: INPUT
number: 14
mode: INPUT
number: 15
mode: INPUT
pcf8574: pcf8574_hub_in_3
mode: INPUT
number: 1
mode: INPUT
number: 2
mode: INPUT
number: 3
mode: INPUT
number: 4
mode: INPUT
number: 5
mode: INPUT
number: 6
mode: INPUT
number: 7
mode: INPUT
number: 8
mode: INPUT
number: 9
mode: INPUT
number: 10
mode: INPUT
number: 11
mode: INPUT
number: 12
mode: INPUT
number: 13
mode: INPUT
number: 14
mode: INPUT
number: 15
mode: INPUT
pcf8574: pcf8574_hub_in_4
mode: INPUT
number: 1
mode: INPUT
number: 2
mode: INPUT
number: 3
mode: INPUT
number: 4
mode: INPUT
number: 5
mode: INPUT
number: 6
mode: INPUT
number: 7
mode: INPUT
number: 8
mode: INPUT
number: 9
mode: INPUT
number: 10
mode: INPUT
number: 11
mode: INPUT
number: 12
mode: INPUT
number: 13
mode: INPUT
number: 14
mode: INPUT
number: 15
mode: INPUT
pcf8574: pcf8574_hub_in_5
mode: INPUT
number: 1
mode: INPUT
number: 2
mode: INPUT
number: 3
mode: INPUT
number: 4
mode: INPUT
number: 5
mode: INPUT
number: 6
mode: INPUT
number: 7
mode: INPUT
number: 8
mode: INPUT
number: 9
mode: INPUT
number: 10
mode: INPUT
number: 11
mode: INPUT
number: 12
mode: INPUT
number: 13
mode: INPUT
number: 14
mode: INPUT
number: 15
mode: INPUT
pcf8574: pcf8574_hub_in_6
mode: INPUT
number: 1
mode: INPUT
number: 2
mode: INPUT
number: 3
mode: INPUT
number: 4
mode: INPUT
number: 5
mode: INPUT
number: 6
mode: INPUT
number: 7
mode: INPUT
number: 8
mode: INPUT
number: 9
mode: INPUT
number: 10
mode: INPUT
number: 11
mode: INPUT
number: 12
mode: INPUT
number: 13
mode: INPUT
number: 14
mode: INPUT
number: 15
mode: INPUT
pcf8574: pcf8574_hub_in_7
mode: INPUT
number: 1
mode: INPUT
number: 2
mode: INPUT
number: 3
mode: INPUT
number: 4
mode: INPUT
number: 5
mode: INPUT
number: 6
mode: INPUT
number: 7
mode: INPUT
number: 8
mode: INPUT
number: 9
mode: INPUT
number: 10
mode: INPUT
number: 11
mode: INPUT
number: 12
mode: INPUT
number: 13
mode: INPUT
number: 14
mode: INPUT
number: 15
mode: INPUT
pcf8574: pcf8574_hub_in_8
mode: INPUT
number: 1
mode: INPUT
number: 2
mode: INPUT
number: 3
mode: INPUT
number: 4
mode: INPUT
number: 5
mode: INPUT
number: 6
mode: INPUT
number: 7
mode: INPUT
number: 8
mode: INPUT
number: 9
mode: INPUT
number: 10
mode: INPUT
number: 11
mode: INPUT
number: 12
mode: INPUT
number: 13
mode: INPUT
number: 14
mode: INPUT
number: 15
mode: INPUT
