[Arduino demo source code for KC868-A4]-12 web server by wifi
[Arduino IDE demo source code for KC868-A4]--#12-WEB_SERVER_CODE
.zip   KC868-A4_Web_Server.zip (Size: 454.76 KB / Downloads: 748)
* Create Your own WebServer for KC868-A4 Smart Controller*
// Load Wi-Fi library
#include <WiFi.h>
#include <WiFiManager.h>
#define TRIGGER_PIN 0   // reset wifi button
WiFiManager wm;
int timeout =20; // seconds to run for
// Replace with your network credentials
/*******config the WIFI by phone*****************/
/* const char* ssid     = "xxx"; //your router's ssid
const char* password = "yyy"; //your router's password*/
WiFiServer server(80);
String header;
// Current time
// Previous time
int flag_read_di=0;
  pinMode(TRIGGER_PIN, INPUT_PULLUP); // wifi reset button
  pinMode(2,OUTPUT);
  pinMode(15,OUTPUT);
  pinMode(5,OUTPUT);
  pinMode(4,OUTPUT);
  pinMode(36,INPUT);
  pinMode(39,INPUT);
  pinMode(27,INPUT);
  pinMode(14,INPUT);
  digitalWrite(2, HIGH);
  digitalWrite(15,HIGH);
  digitalWrite(5, HIGH);
  digitalWrite(4, HIGH);
    WiFi.mode(WIFI_STA);
    wm.setConfigPortalTimeout(timeout);
     bool res;
       res = wm.autoConnect("KC868-A4-AP"); // anonymous ap
    if(!res) {
        Serial.println("Failed to connect");
    else {
        Serial.println("connected...yeey :)");
  Serial.println("");
  Serial.println("WiFi connected.");
  Serial.println("IP address: ");
  server.begin();
void loop(){
  WiFiClient client = server.available();   // Listen for incoming clients
  if (client) {                             // If a new client connects,
    currentTime = millis();
    previousTime = currentTime;
      if (client.available()) {             // if there's bytes to read from the client,
        char c = client.read();             // read a byte, then
        header += c;
            client.println();
            // turns 16 relays on and off
                 if (header.indexOf("GET /1/on") >= 0)  {relay1state = "on"; digitalWrite(2, HIGH);}
            else if (header.indexOf("GET /1/off") >= 0) {relay1state = "off";digitalWrite(2, LOW);}
            else if (header.indexOf("GET /2/on") >= 0)  {relay2state = "on"; digitalWrite(15, HIGH);}
            else if (header.indexOf("GET /2/off") >= 0) {relay2state = "off";digitalWrite(15, LOW);}
            else if (header.indexOf("GET /3/on") >= 0)  {relay3state = "on"; digitalWrite(5, HIGH);}
            else if (header.indexOf("GET /3/off") >= 0) {relay3state = "off";digitalWrite(5, LOW);}
            else if (header.indexOf("GET /4/on") >= 0)  {relay4state = "on"; digitalWrite(4, HIGH);}
            else if (header.indexOf("GET /4/off") >= 0) {relay4state = "off";digitalWrite(4, LOW);}
                digitalWrite(15,LOW);
            // Display the HTML web page
            client.println("<style>html { font-family: Helvetica; display: inline-block; border: 3px solid green;margin: 0px 15px;}");
            client.println(".button { background-color: #195B00; border-radius: 10px;color: white; padding: 10px 40px;");
            client.println("text-decoration: none; font-size: 20px; margin: 2px;text-align: center; cursor: pointer;}");
            if (flag_read_di==1)
              client.println(" relay1:" + relay1state + " relay2:" + relay2state + " relay3:" + relay3state + " relay4:" + relay4state );
            else
            // Web Page Heading
            client.println("<body><h1>KC868-A4 Web Server</h1>");
              client.println("<a href=\"/all/on\"><button class=\"button\">All-ON</button></a>");
              client.println("<a href=\"/all/off\"><button class=\"button\">All-OFF</button></a>");
            client.println();
            break;
            currentLine = "";
    // Clear the header variable
    header = "";
    // Close the connection
    client.stop();
    Serial.println("");
    flag_read_di=0;
void ScanKey()
    if(digitalRead(36) == LOW)         //key pressed
        delay(20);
        if(digitalRead(36) == LOW)       //key pressed again
          digitalWrite(2,!digitalRead(2));    // toggle relay1 state
          while(digitalRead(36) == LOW); //wait remove hand
          if (digitalRead(2) == LOW) relay1state="on";else relay1state="off";
if(digitalRead(39) == LOW)         //key pressed
        delay(20);
        if(digitalRead(39) == LOW)       //key pressed again
          digitalWrite(15,!digitalRead(15));    // toggle relay1 state
          while(digitalRead(39) == LOW); //wait remove hand
          if (digitalRead(15) == LOW) relay2state="on";else relay2state="off";
    if(digitalRead(27) == LOW)         //key pressed
        delay(20);
        if(digitalRead(27) == LOW)       //key pressed again
          digitalWrite(5,!digitalRead(5));    // toggle relay1 state
          while(digitalRead(27) == LOW); //wait remove hand
          if (digitalRead(5) == LOW) relay3state="on";else relay3state="off";
      if(digitalRead(14) == LOW)         //key pressed
            delay(20);
            if(digitalRead(14) == LOW)       //key pressed again
              digitalWrite(4,!digitalRead(4));    // toggle relay1 state
              while(digitalRead(14) == LOW); //wait remove hand
              if (digitalRead(4) == LOW) relay4state="on";else relay4state="off";
