  • 1 Vote(s) - 5 Average
[Arduino IDE demo source code for KC868-A8]--#10-Web server_code
.zip   KC868-A8_Web_Server.zip (Size: 462.26 KB / Downloads: 741)
* Create Your own WebServer for KC868-A8 Smart Controller*
// Load Wi-Fi library
#include <WiFi.h>
#include "PCF8574.h"
#include <WiFiManager.h>
#define TRIGGER_PIN 0   // reset wifi button
WiFiManager wm;
int timeout =20; // seconds to run for
// Replace with your network credentials
/*******config the WIFI by phone*****************/
/* const char* ssid     = "xxx"; //your router's ssid
const char* password = "yyy"; //your router's password*/
WiFiServer server(80);
String header;
// Current time
// Previous time
int flag_read_di=0;
TwoWire I2Cone = TwoWire(0);
//set I2C of A8
PCF8574 pcf8574_I1(&I2Cone,0x22,4,5);
PCF8574 pcf8574_R1(&I2Cone,0x24,4,5);
String relaystate[8]={"relay1state","relay2state","relay3state","relay4state",
                       "relay5state","relay6state","relay7state","relay8state",
  pinMode(TRIGGER_PIN, INPUT_PULLUP); // wifi reset button
  for(int i=0;i<=7;i++)
  pcf8574_R1.begin();
     pcf8574_I1.pinMode(i, INPUT);
    pcf8574_I1.begin();
    WiFi.mode(WIFI_STA);
    wm.setConfigPortalTimeout(timeout);
     bool res;
       res = wm.autoConnect("KC868-A8-AP"); // anonymous ap
    if(!res) {
        Serial.println("Failed to connect");
    else {
        Serial.println("connected...yeey :)");
  Serial.println("");
  Serial.println("WiFi connected.");
  Serial.println("IP address: ");
  server.begin();
void loop(){
  WiFiClient client = server.available();   // Listen for incoming clients
  if (client) {                             // If a new client connects,
    currentTime = millis();
    previousTime = currentTime;
      if (client.available()) {             // if there's bytes to read from the client,
        char c = client.read();             // read a byte, then
        header += c;
            client.println();
            // turns 16 relays on and off
                 pcf8574_R1.digitalWrite(i, LOW);
            // Display the HTML web page
            client.println("<style>html { font-family: Helvetica; display: inline-block; border: 3px solid green;margin: 0px 15px;}");
            client.println(".button { background-color: #195B00; border-radius: 10px;color: white; padding: 10px 40px;");
            client.println("text-decoration: none; font-size: 20px; margin: 2px;text-align: center; cursor: pointer;}");
            if (flag_read_di==1)
              client.println(" relay1:" + relay1state + " relay2:" + relay2state + " relay3:" + relay3state + " relay4:" + relay4state + " relay5:" + relay5state + " relay6:" + relay6state + " relay7:" + relay7state + " relay8:" + relay8state);
            else
            // Web Page Heading
            client.println("<body><h1>KC868-A8 Web Server</h1>");
            if (relay5state == "off") client.println("<a href=\"/5/on\"><button class=\"button\">05-OFF</button></a>"); else client.println("<a href=\"/5/off\"><button class=\"button\">05-ON </button></a>");
            if (relay6state == "off") client.println("<a href=\"/6/on\"><button class=\"button\">06-OFF</button></a>"); else client.println("<a href=\"/6/off\"><button class=\"button\">06-ON </button></a>");
            if (relay7state == "off") client.println("<a href=\"/7/on\"><button class=\"button\">07-OFF</button></a>"); else client.println("<a href=\"/7/off\"><button class=\"button\">07-ON </button></a>");
            if (relay8state == "off") client.println("<a href=\"/8/on\"><button class=\"button\">08-OFF</button></a>"); else client.println("<a href=\"/8/off\"><button class=\"button\">08-ON </button></a>");
              client.println("<a href=\"/all/on\"><button class=\"button\">All-ON</button></a>");
              client.println("<a href=\"/all/off\"><button class=\"button\">All-OFF</button></a>");
            client.println();
            break;
            currentLine = "";
    // Clear the header variable
    header = "";
    // Close the connection
    client.stop();
    Serial.println("");
    flag_read_di=0;
void ScanKey()
    if(pcf8574_I1.digitalRead(i) == LOW)         //key pressed
        delay(20);
        if(pcf8574_I1.digitalRead(i) == LOW)       //key pressed again
