[Arduino IDE demo source code for KC868-A16]--#09-KC868-A16_Web_server_code
.zip   KC868-A16_Web_Server.zip (Size: 464.75 KB / Downloads: 1,362)
* Create Your own WebServer for KC868-A16 Smart Controller*
// Load Wi-Fi library
#include <WiFi.h>
#include "PCF8574.h"
#include <WiFiManager.h>
#define TRIGGER_PIN 0   // reset wifi button
WiFiManager wm;
int timeout =20; // seconds to run for
// Replace with your network credentials
/*******config the WIFI by phone*****************/
/* const char* ssid     = "xxx"; //your router's ssid
const char* password = "yyy"; //your router's password*/
WiFiServer server(80);
String header;
// Current time
// Previous time
int flag_read_di=0;
TwoWire I2Cone = TwoWire(0);
TwoWire I2Ctwo = TwoWire(1);
/*******Check the I2C address **********/
/********If your board was purchased earlier, use an older I2C**/
/********OLD A16 Board I2C address */
PCF8574 pcf8574_I1(&I2Cone,0x22,4,5);
PCF8574 pcf8574_I2(&I2Cone,0x21,4,5);
PCF8574 pcf8574_R1(&I2Cone,0x24,4,5);
PCF8574 pcf8574_R2(&I2Cone,0x25,4,5);*/
// Set A16 digital input i2c address
/********NEW A16 Board I2C address */
PCF8574 pcf8574_I1(&I2Cone,0x3A,4,5);
PCF8574 pcf8574_I2(&I2Cone,0x39,4,5);
PCF8574 pcf8574_R1(&I2Cone,0x3C,4,5);
PCF8574 pcf8574_R2(&I2Cone,0x3D,4,5);
String relaystate[16]={"relay1state","relay2state","relay3state","relay4state",
                       "relay5state","relay6state","relay7state","relay8state",
                       "relay9state","relay10state","relay11state","relay12state",
                       "relay13state","relay14state","relay15state","relay16state"
  pinMode(TRIGGER_PIN, INPUT_PULLUP); // wifi reset button
  for(int i=0;i<=7;i++)
     pcf8574_R2.pinMode(i, OUTPUT);
  pcf8574_R1.begin();
  pcf8574_R2.begin();
     pcf8574_I1.pinMode(i, INPUT);
     pcf8574_I2.pinMode(i, INPUT);
    pcf8574_I1.begin();
    pcf8574_I2.begin();
     pcf8574_R2.digitalWrite(i, HIGH);
    WiFi.mode(WIFI_STA);
    wm.setConfigPortalTimeout(timeout);
     bool res;
       res = wm.autoConnect("KC868-A16-AP"); // anonymous ap
    if(!res) {
        Serial.println("Failed to connect");
    else {
        Serial.println("connected...yeey :)");
  Serial.println("");
  Serial.println("WiFi connected.");
  Serial.println("IP address: ");
  server.begin();
void loop(){
  WiFiClient client = server.available();   // Listen for incoming clients
    currentTime = millis();
    previousTime = currentTime;
        header += c;
            client.println();
            // turns 16 relays on and off
                 pcf8574_R1.digitalWrite(i, LOW);
                 pcf8574_R2.digitalWrite(i, LOW);
            // Display the HTML web page
            client.println("<style>html { font-family: Helvetica; display: inline-block; border: 3px solid green;margin: 0px 15px;}");
            client.println(".button { background-color: #195B00; border-radius: 10px;color: white; padding: 10px 40px;");
            client.println("text-decoration: none; font-size: 20px; margin: 2px;text-align: center; cursor: pointer;}");
            if (flag_read_di==1)
              client.println(" relay1:" + relay1state + " relay2:" + relay2state + " relay3:" + relay3state + " relay4:" + relay4state + " relay5:" + relay5state + " relay6:" + relay6state + " relay7:" + relay7state + " relay8:" + relay8state + " relay9:" + relay9state + " relay10:" + relay10state + " relay11:" + relay11state + " relay12:" + relay12state + " relay13:" + relay13state + " relay14:" + relay14state + " relay15:" + relay15state + " relay16:" + relay16state);
            else
            // Web Page Heading
            client.println("<body><h1>KC868-A16 Web Server</h1>");
            if (relay5state == "off") client.println("<a href=\"/5/on\"><button class=\"button\">05-OFF</button></a>"); else client.println("<a href=\"/5/off\"><button class=\"button\">05-ON </button></a>");
            if (relay6state == "off") client.println("<a href=\"/6/on\"><button class=\"button\">06-OFF</button></a>"); else client.println("<a href=\"/6/off\"><button class=\"button\">06-ON </button></a>");
            if (relay7state == "off") client.println("<a href=\"/7/on\"><button class=\"button\">07-OFF</button></a>"); else client.println("<a href=\"/7/off\"><button class=\"button\">07-ON </button></a>");
            if (relay8state == "off") client.println("<a href=\"/8/on\"><button class=\"button\">08-OFF</button></a>"); else client.println("<a href=\"/8/off\"><button class=\"button\">08-ON </button></a>");
            if (relay9state == "off") client.println("<a href=\"/9/on\"><button class=\"button\">09-OFF</button></a>"); else client.println("<a href=\"/9/off\"><button class=\"button\">09-ON </button></a>");
            if (relay10state == "off") client.println("<a href=\"/10/on\"><button class=\"button\">10-OFF</button></a>"); else client.println("<a href=\"/10/off\"><button class=\"button\">10-ON</button></a>");
            if (relay11state == "off") client.println("<a href=\"/11/on\"><button class=\"button\">11-OFF</button></a>"); else client.println("<a href=\"/11/off\"><button class=\"button\">11-ON</button></a>");
            if (relay12state == "off") client.println("<a href=\"/12/on\"><button class=\"button\">12-OFF</button></a>"); else client.println("<a href=\"/12/off\"><button class=\"button\">12-ON</button></a>");
            if (relay13state == "off") client.println("<a href=\"/13/on\"><button class=\"button\">13-OFF</button></a>"); else client.println("<a href=\"/13/off\"><button class=\"button\">13-ON</button></a>");
            if (relay14state == "off") client.println("<a href=\"/14/on\"><button class=\"button\">14-OFF</button></a>"); else client.println("<a href=\"/14/off\"><button class=\"button\">14-ON</button></a>");
            if (relay15state == "off") client.println("<a href=\"/15/on\"><button class=\"button\">15-OFF</button></a>"); else client.println("<a href=\"/15/off\"><button class=\"button\">15-ON</button></a>");
            if (relay16state == "off") client.println("<a href=\"/16/on\"><button class=\"button\">16-OFF</button></a>"); else client.println("<a href=\"/16/off\"><button class=\"button\">16-ON</button></a>");
              client.println("<a href=\"/all/on\"><button class=\"button\">All-ON</button></a>");
              client.println("<a href=\"/all/off\"><button class=\"button\">All-OFF</button></a>");
            client.println();
            break;
            currentLine = "";
    // Clear the header variable
    header = "";
    // Close the connection
    client.stop();
    Serial.println("");
    flag_read_di=0;
void ScanKey()
    if(pcf8574_I1.digitalRead(i) == LOW)         //key pressed
        delay(20);
        if(pcf8574_I1.digitalRead(i) == LOW)       //key pressed again
    for(int j=0;j<=7;j++)
    if(pcf8574_I2.digitalRead(j) == LOW)         //key pressed
        delay(20);
        if(pcf8574_I2.digitalRead(j) == LOW)       //key pressed again
          pcf8574_R2.digitalWrite(j,!pcf8574_R2.digitalRead(j));    // toggle relay1 state
          while(pcf8574_I2.digitalRead(j) == LOW); //wait remove hand
          if (pcf8574_R2.digitalRead(j) == LOW) relaystate[j+8]="on";else relaystate[j+8]="off";
hello
I downloaded the zip file "KC868-A16 Web_Server" when I compile it I get
the following error message
I'm still a beginner with KC868-A16 and need help
thank you in advance
/home/arduino/Downloads/KC868-A16_Web_Server/KC868-A16_Web_Server.ino:50:36: error: no matching function for call to 'PCF8574:TongueCF8574(TwoWire*, int, int, int)'
  50 | PCF8574 pcf8574_I1(&I2Cone,0x3A,4,5);
In file included from /home/arduino/Downloads/KC868-A16_Web_Server/KC868-A16_Web_Server.ino:8:
/home/arduino/Arduino/libraries/PCF8574/PCF8574.h:30:12: note: candidate: 'PCF8574:TongueCF8574(uint8_t, TwoWire*)'
  30 |  explicit PCF8574(const uint8_t deviceAddress = 0x20, TwoWire *wire = &Wire);
/home/arduino/Arduino/libraries/PCF8574/PCF8574.h:30:12: note:  candidate expects 2 arguments, 4 provided
/home/arduino/Arduino/libraries/PCF8574/PCF8574.h:27:7: note: candidate: 'constexpr PCF8574:TongueCF8574(const PCF8574&)'
  27 | class PCF8574
/home/arduino/Arduino/libraries/PCF8574/PCF8574.h:27:7: note:  candidate expects 1 argument, 4 provided
/home/arduino/Arduino/libraries/PCF8574/PCF8574.h:27:7: note: candidate: 'constexpr PCF8574:TongueCF8574(PCF8574&&)'
/home/arduino/Downloads/KC868-A16_Web_Server/KC868-A16_Web_Server.ino:51:36: error: no matching function for call to 'PCF8574:TongueCF8574(TwoWire*, int, int, int)'
  51 | PCF8574 pcf8574_I2(&I2Cone,0x39,4,5);
  27 | class PCF8574
/home/arduino/Downloads/KC868-A16_Web_Server/KC868-A16_Web_Server.ino:52:36: error: no matching function for call to 'PCF8574:TongueCF8574(TwoWire*, int, int, int)'
  52 | PCF8574 pcf8574_R1(&I2Cone,0x3C,4,5);
and more errors
exit status 1
Compilation error: no matching function for call to 'PCF8574:TongueCF8574(TwoWire*, int, int, int)'
you need to install PCF8574 arduino library firstly.
Thank you for the quick reply
I had an older version of "PCF8574.h" installed
after reinstalling it works perfectly.
Now I wanted to test the ETH version
I have installed <WebServer_WT32_ETH01.h> 1.5.1
but unfortunately I get the following error message
In file included from /home/arduino/Arduino/WebServer_WT32_ETH01-main/examples/ESP32_FS_EthernetWebServer/ESP32_FS_EthernetWebServer.ino:77:
/home/arduino/Arduino/libraries/WebServer_WT32_ETH01/src/WebServer_WT32_ETH01.h:63:4: error: #error This code is designed to run on ESP32 platform! Please check your Tools->Board setting.
63 | #error This code is designed to run on ESP32 platform! Please check your Tools->Board setting.
exit status 1
Compilation error: exit status 1
I need your help again
thank you
you need config library for LAN8720
#define ETH_ADDR 0
#define ETH_POWER_PIN -1
#define ETH_MDC_PIN 23
#define ETH_MDIO_PIN 18
#define ETH_TYPE ETH_PHY_LAN8720
#define ETH_CLK_MODE ETH_CLOCK_GPIO17_OUT
exit status 1
thank you
it already told you need chose ESP32 DEV board in arduino IDE.
Hello
I tried it with
ESP32P4 DEV Module
ESP32P2 DEV Module
ESP32C6 DEV Module
ESP32S3 DEV Module
ESP32C3 DEV Module
ESP32S2 DEV Module
ESP32 DEV Module
the error is always displayed
could it be due to outdated firmware?
if so, do you have an update guide for me?
best regards
wolli
In file included from /tmp/.arduinoIDE-unsaved202527-1777-1o0olpa.8wkj/HelloServer/HelloServer.ino:18:
exit status 1
take a photo of your arduino IDE error screen and what board you have selected.
Hello
I have a KC868-A16
I've recently performed an update
KCS_KC868_A16_V2.2.2.bin
The LEDs on the Ethernet interface are now lit
but I still get the error message
  WebServer.ino - Simple Arduino web server sample for Ethernet shield
  For Ethernet shields using WT32_ETH01 (ESP32 + LAN8720)
  WebServer_WT32_ETH01 is a library for the Ethernet LAN8720 in WT32_ETH01 to run WebServer
  Based on and modified from ESP8266 https://github.com/esp8266/Arduino/releases
  Built by Khoi Hoang https://github.com/khoih-prog/WebServer_WT32_ETH01
  Licensed under MIT license
#define DEBUG_ETHERNET_WEBSERVER_PORT      Serial
// Debug Level from 0 to 4
#define _ETHERNET_WEBSERVER_LOGLEVEL_      3
#include <WebServer_WT32_ETH01.h>
// Select the IP address according to your local network
IPAddress myIP(192, 168, 2, 232);
IPAddress myGW(192, 168, 2, 1);
IPAddress mySN(255, 255, 255, 0);
// Google DNS Server IP
IPAddress myDNS(8, 8, 8, 8);
In file included from /tmp/.arduinoIDE-unsaved2025212-12431-f36wql.f8x/WebServer/WebServer.ino:19:
exit status 1
