[Arduino IDE demo source code for KC868-E16S]--#07-KC868-E16S-Web_server_code
.zip   KC868-E16S_Web_Server.zip (Size: 464.69 KB / Downloads: 599)
* Create Your own WebServer for KC868-E16S Smart Controller*
// Load Wi-Fi library
#include <WiFi.h>
#include "PCF8574.h"
#include <WiFiManager.h>
#define TRIGGER_PIN 0   // reset wifi button
WiFiManager wm;
int timeout =20; // seconds to run for
WiFiServer server(80);
String header;
// Current time
// Previous time
int flag_read_di=0;
TwoWire I2Cone = TwoWire(0);
TwoWire I2Ctwo = TwoWire(1);
PCF8574 pcf8574_I1(&I2Cone, 0x22, 16, 15);
PCF8574 pcf8574_I2(&I2Cone, 0x24, 16, 15);
PCF8574 pcf8574_R1(&I2Cone, 0x21, 16, 15);
PCF8574 pcf8574_R2(&I2Cone, 0x25, 16, 15);
String relaystate[16]={"relay1state","relay2state","relay3state","relay4state","relay5state","relay6state","relay7state","relay8state",
                       "relay9state","relay10state","relay11state","relay12state","relay13state","relay14state","relay15state","relay16state",};
  pinMode(TRIGGER_PIN, INPUT_PULLUP); // wifi reset button
  for(int i=0;i<=7;i++)
     pcf8574_R2.pinMode(i, OUTPUT);
  pcf8574_R1.begin();
  pcf8574_R2.begin();
     pcf8574_I1.pinMode(i, INPUT);
     pcf8574_I2.pinMode(i, INPUT);
  pcf8574_I1.begin();
  pcf8574_I2.begin();
     pcf8574_R2.digitalWrite(i, HIGH);
// Connect to Wi-Fi network with SSID and password
// Serial.print("Connecting to ");
// Serial.println(ssid);
  WiFi.mode(WIFI_STA);
  //WiFi.begin(ssid, password);
    wm.setConfigPortalTimeout(timeout);
     bool res;
    // res = wm.autoConnect(); // auto generated AP name from chipid
       res = wm.autoConnect("KC868-E16S-AP"); // anonymous ap
   //  res = wm.autoConnect("AutoConnectAP","password"); // password protected ap
    if(!res) {
        Serial.println("Failed to connect");
        // ESP.restart();
    else {
        Serial.println("connected...yeey :)");
  Serial.println("");
  Serial.println("WiFi connected.");
  Serial.println("IP address: ");
  server.begin();
void loop(){
  WiFiClient client = server.available();   // Listen for incoming clients
    currentTime = millis();
    previousTime = currentTime;
        header += c;
            client.println();
            // turns 16 relays on and off
                 pcf8574_R1.digitalWrite(i, LOW);
                 pcf8574_R2.digitalWrite(i, LOW);
            // Display the HTML web page
            client.println("<style>html { font-family: Helvetica; display: inline-block; margin: 0px auto; text-align: center;}");
            client.println(".button { background-color: #195B6A; border: none; color: white; padding: 16px 40px;");
            client.println("text-decoration: none; font-size: 30px; margin: 2px; cursor: pointer;}");
            if (flag_read_di==1)
              client.println(" relay1:" + relay1state + " relay2:" + relay2state + " relay3:" + relay3state + " relay4:" + relay4state + " relay5:" + relay5state + " relay6:" + relay6state + " relay7:" + relay7state + " relay8:" + relay8state + " relay9:" + relay9state + " relay10:" + relay10state + " relay11:" + relay11state + " relay12:" + relay12state + " relay13:" + relay13state + " relay14:" + relay14state + " relay15:" + relay15state + " relay16:" + relay16state);
            else
            // Web Page Heading
            client.println("<body><h1>KC868-E16S Web Server</h1>");
            if (relay5state == "off") client.println("<a href=\"/5/on\"><button class=\"button\">05-OFF</button></a>"); else client.println("<a href=\"/5/off\"><button class=\"button\">05-ON </button></a>");
            if (relay6state == "off") client.println("<a href=\"/6/on\"><button class=\"button\">06-OFF</button></a>"); else client.println("<a href=\"/6/off\"><button class=\"button\">06-ON </button></a>");
            if (relay7state == "off") client.println("<a href=\"/7/on\"><button class=\"button\">07-OFF</button></a>"); else client.println("<a href=\"/7/off\"><button class=\"button\">07-ON </button></a>");
            if (relay8state == "off") client.println("<a href=\"/8/on\"><button class=\"button\">08-OFF</button></a>"); else client.println("<a href=\"/8/off\"><button class=\"button\">08-ON </button></a>");
            if (relay9state == "off") client.println("<a href=\"/9/on\"><button class=\"button\">09-OFF</button></a>"); else client.println("<a href=\"/9/off\"><button class=\"button\">09-ON </button></a>");
            if (relay10state == "off") client.println("<a href=\"/10/on\"><button class=\"button\">10-OFF</button></a>"); else client.println("<a href=\"/10/off\"><button class=\"button\">10-ON</button></a>");
            if (relay11state == "off") client.println("<a href=\"/11/on\"><button class=\"button\">11-OFF</button></a>"); else client.println("<a href=\"/11/off\"><button class=\"button\">11-ON</button></a>");
            if (relay12state == "off") client.println("<a href=\"/12/on\"><button class=\"button\">12-OFF</button></a>"); else client.println("<a href=\"/12/off\"><button class=\"button\">12-ON</button></a>");
            if (relay13state == "off") client.println("<a href=\"/13/on\"><button class=\"button\">13-OFF</button></a>"); else client.println("<a href=\"/13/off\"><button class=\"button\">13-ON</button></a>");
            if (relay14state == "off") client.println("<a href=\"/14/on\"><button class=\"button\">14-OFF</button></a>"); else client.println("<a href=\"/14/off\"><button class=\"button\">14-ON</button></a>");
            if (relay15state == "off") client.println("<a href=\"/15/on\"><button class=\"button\">15-OFF</button></a>"); else client.println("<a href=\"/15/off\"><button class=\"button\">15-ON</button></a>");
            if (relay16state == "off") client.println("<a href=\"/16/on\"><button class=\"button\">16-OFF</button></a>"); else client.println("<a href=\"/16/off\"><button class=\"button\">16-ON</button></a>");
              client.println("<a href=\"/all/on\"><button class=\"button\">all ON</button></a>");
              client.println("<a href=\"/all/off\"><button class=\"button\">all OFF</button></a>");
            client.println();
            break;
            currentLine = "";
    // Clear the header variable
    header = "";
    // Close the connection
    client.stop();
    Serial.println("");
    flag_read_di=0;
void ScanKey()
    if(pcf8574_I1.digitalRead(i) == LOW)         //key pressed
        delay(20);
        if(pcf8574_I1.digitalRead(i) == LOW)       //key pressed again
    for(int j=0;j<=7;j++)
    if(pcf8574_I2.digitalRead(j) == LOW)         //key pressed
        delay(20);
        if(pcf8574_I2.digitalRead(j) == LOW)       //key pressed again
          pcf8574_R2.digitalWrite(j,!pcf8574_R2.digitalRead(j));    // toggle relay1 state
          while(pcf8574_I2.digitalRead(j) == LOW); //wait remove hand
          if (pcf8574_R2.digitalRead(j) == LOW) relaystate[j+8]="on";else relaystate[j+8]="off";
