  • 1 Vote(s) - 5 Average
[Arduino IDE demo source code for KC868-A8]--#11-Ethernet_Web server_code
.zip   KC868-A8_Web_Server-ETH.zip (Size: 33.43 MB / Downloads: 1,259)
* Create Your own WebServer for KC868-A8 Smart Controller*
#include "PCF8574.h"
#define DEBUG_ETHERNET_WEBSERVER_PORT       Serial
// Debug Level from 0 to 4
#define _ETHERNET_WEBSERVER_LOGLEVEL_       3
#include <WebServer_WT32_ETH01.h>
WiFiServer server(80);
// Current time
// Previous time
int flag_read_di=0;
String header;
TwoWire I2Cone = TwoWire(0);
TwoWire I2Ctwo = TwoWire(1);
//set I2C of A8
PCF8574 pcf8574_I1(&I2Cone,0x22,4,5);
PCF8574 pcf8574_R1(&I2Cone,0x24,4,5);
String relaystate[8]={"relay1state","relay2state","relay3state","relay4state",
                       "relay5state","relay6state","relay7state","relay8state",
void ScanKey()
  for(int i=0;i<=7;i++)
    if(pcf8574_I1.digitalRead(i) == LOW)         //key pressed
        delay(20);
        if(pcf8574_I1.digitalRead(i) == LOW)       //key pressed again
  pcf8574_R1.begin();
     pcf8574_I1.pinMode(i, INPUT);
    pcf8574_I1.begin();
   while (!Serial);
  // Using this if Serial debugging is not necessary or not using Serial port
  //while (!Serial && (millis() < 3000));
  Serial.print("\nStarting WebServer on " + String(ARDUINO_BOARD));
  Serial.println(" with " + String(SHIELD_TYPE));
  Serial.println(WEBSERVER_WT32_ETH01_VERSION);
  WT32_ETH01_onEvent();
  //bool begin(uint8_t phy_addr=ETH_PHY_ADDR, int power=ETH_PHY_POWER, int mdc=ETH_PHY_MDC, int mdio=ETH_PHY_MDIO,
  //           eth_phy_type_t type=ETH_PHY_TYPE, eth_clock_mode_t clk_mode=ETH_CLK_MODE);
  //ETH.begin(ETH_PHY_ADDR, ETH_PHY_POWER, ETH_PHY_MDC, ETH_PHY_MDIO, ETH_PHY_TYPE, ETH_CLK_MODE);
  ETH.begin(ETH_PHY_ADDR, ETH_PHY_POWER);
// ETH.config(myIP, myGW, mySN, myDNS);
  //WT32_ETH01_waitForConnect();
  // start the web server on port 80
  server.begin();
void loop(){
  WiFiClient client = server.available();   // Listen for incoming clients
  if (client) {                             // If a new client connects,
    currentTime = millis();
    previousTime = currentTime;
      if (client.available()) {             // if there's bytes to read from the client,
        char c = client.read();             // read a byte, then
        header += c;
            client.println();
            // turns 16 relays on and off
                 pcf8574_R1.digitalWrite(i, LOW);
            // Display the HTML web page
            client.println("<style>html { font-family: Helvetica; display: inline-block; border: 3px solid green;margin: 0px auto;text-align: center;font-size: 10px;}");
            client.println(".button { background-color: #195B00; border-radius: 10px;color: white; padding: 10px 40px;");
            client.println("text-decoration: none; font-size: 20px; margin: 2px;text-align: center; cursor: pointer;}");
            if (flag_read_di==1)
              client.println(" relay1:" + relay1state + " relay2:" + relay2state + " relay3:" + relay3state + " relay4:" + relay4state + " relay5:" + relay5state + " relay6:" + relay6state + " relay7:" + relay7state + " relay8:" + relay8state);
            else
            // Web Page Heading
            client.println("<body><h1>KC868-A8 Web Server</h1>");
            if (relay1state == "off") client.println("<a href=\"/1/on\"><button class=\"button\">01-OFF</button></a>"); else client.println("<a href=\"/1/off\"><button class=\"button\">01--ON </button></a>");
            if (relay2state == "off") client.println("<a href=\"/2/on\"><button class=\"button\">02-OFF</button></a>"); else client.println("<a href=\"/2/off\"><button class=\"button\">02--ON </button></a>");
            if (relay3state == "off") client.println("<a href=\"/3/on\"><button class=\"button\">03-OFF</button></a>"); else client.println("<a href=\"/3/off\"><button class=\"button\">03--ON </button></a>");
            if (relay4state == "off") client.println("<a href=\"/4/on\"><button class=\"button\">04-OFF</button></a>"); else client.println("<a href=\"/4/off\"><button class=\"button\">04--ON </button></a>");
            if (relay5state == "off") client.println("<a href=\"/5/on\"><button class=\"button\">05-OFF</button></a>"); else client.println("<a href=\"/5/off\"><button class=\"button\">05--ON </button></a>");
            if (relay6state == "off") client.println("<a href=\"/6/on\"><button class=\"button\">06-OFF</button></a>"); else client.println("<a href=\"/6/off\"><button class=\"button\">06--ON </button></a>");
            if (relay7state == "off") client.println("<a href=\"/7/on\"><button class=\"button\">07-OFF</button></a>"); else client.println("<a href=\"/7/off\"><button class=\"button\">07--ON </button></a>");
            if (relay8state == "off") client.println("<a href=\"/8/on\"><button class=\"button\">08-OFF</button></a>"); else client.println("<a href=\"/8/off\"><button class=\"button\">08--ON </button></a>");
              client.println("<a href=\"/all/on\"><button class=\"button\">All--ON</button></a>");
              client.println("<a href=\"/all/off\"><button class=\"button\">All-OFF</button></a>");
            client.println();
            break;
            currentLine = "";
    // Clear the header variable
    header = "";
    // Close the connection
    client.stop();
    Serial.println("");
    flag_read_di=0;
(09-05-2022, 03:12 AM)KinCony Support Wrote: [Arduino IDE demo source code for KC868-A8]--#11-Ethernet_Web server_code
if you want to use the Arduino source code ,you should install "WebServer_WT32_ETH01 "library first;
then you should find the file named  "WebServer_WT32_ETH01.hpp" and change the GPIO0 TO GPIO17;
Hi
after flashing the firmware, i got below error:
10:27:18.702 -> ets Jul 29 2019 12:21:46
10:27:18.702 ->
10:27:18.702 -> rst:0x3 (SW_RESET),boot:0x17 (SPI_FAST_FLASH_BOOT)
10:27:18.702 -> configsip: 0, SPIWP:0xee
10:27:18.733 -> clk_drv:0x00,q_drv:0x00,d_drv:0x00,cs0_drv:0x00,hd_drv:0x00,wp_drv:0x00
10:27:18.733 -> mode: DIO, clock div:2
10:27:18.733 -> load:0x3fff0030,len:6656
10:27:18.733 -> load:0x40078000,len:15052
10:27:18.733 -> load:0x40080400,len:3836
10:27:18.733 -> entry 0x4008069c
10:27:18.733 -> I (52) boot: ESP-IDF v4.4.7-dirty 2nd stage bootloader
10:27:18.733 -> I (53) boot: compile time 12:46:57
10:27:18.733 -> I (53) boot: Multicore bootloader
10:27:18.767 -> I (57) boot: chip revision: v3.1
10:27:18.767 -> I (61) boot.esp32: SPI Speed      : 40MHz
10:27:18.767 -> I (65) boot.esp32: SPI Mode      : DIO
10:27:18.767 -> I (70) boot.esp32: SPI Flash Size : 4MB
10:27:18.767 -> I (75) boot: Enabling RNG early entropy source...
10:27:18.767 -> I (80) boot: Partition Table:
10:27:18.767 -> I (84) boot: ## Label            Usage          Type ST Offset  Length
10:27:18.799 -> I (91) boot:  0 nvs              WiFi data        01 02 00009000 00026000
10:27:18.799 -> I (98) boot:  1 phy_init        RF data          01 01 0003f000 00001000
10:27:18.799 -> I (106) boot:  2 factory          factory app      00 00 00040000 003b0000
10:27:18.799 -> I (113) boot: End of partition table
10:27:18.799 -> E (118) esp_image: image at 0x40000 has invalid magic byte (nothing flashed here?)
10:27:18.832 -> E (126) boot: Factory app partition is not bootable
10:27:18.832 -> E (131) boot: No bootable app partitions in the partition table
10:27:18.832 -> ets Jul 29 2019 12:21:46
your support is highly appreciated.
do you use arduino ide or esp-idf?
esp-idf
this is arduino source code.
that is correct. when the board didn't boot after flashing the firmware. i connect it to arduino only to get any possible log through serial.
