09-27-2022, 05:34 AM
i have used on board extend serial port. actually use want to use VCC,GND,RXD,TXD for Nextion display.
define RXD:GPIO13 TXD:GPIO12 by ESP32
weld Vcc 5V from LM1117 output pin.
here are some photos:
This just a simplest demo, use Nextion display two buttons, press button-one will send 'a' by serial port, press button-two will send 'b' by serial port.
when KC868-A4 received 'a' will turn ON relay1, when received 'b' will turn OFF relay1.
firstly create two buttons UI by Nextion Editor PC software:
here is firmware BIN file, you can download to KC868-A4 ESP32 directly to use:
nextion_KC868-A6.ino.nodemcu-32s.zip (Size: 108.86 KB / Downloads: 615)
here are source code:
#include "PCF8574.h"
String indata="";
String val="";
// Set i2c address
PCF8574 pcf8574(0x24);
Serial1.begin(9600,SERIAL_8N1,13,12);
Serial.begin(9600);
pcf8574.pinMode(P0, OUTPUT);
pcf8574.pinMode(P1, OUTPUT);
pcf8574.pinMode(P2, OUTPUT);
pcf8574.pinMode(P3, OUTPUT);
pcf8574.pinMode(P4, OUTPUT);
pcf8574.pinMode(P5, OUTPUT);
if (pcf8574.begin()){
Serial.println("OK");
}else{
Serial.println("KO");
pcf8574.digitalWrite(P0, HIGH);
pcf8574.digitalWrite(P1, HIGH);
pcf8574.digitalWrite(P2, HIGH);
pcf8574.digitalWrite(P3, HIGH);
pcf8574.digitalWrite(P4, HIGH);
pcf8574.digitalWrite(P5, HIGH);
while(Serial1.available()>0)
indata+=char(Serial1.read());
delay(2);
if(Serial1.available()<=0)
Serial.println(indata);
if(indata.length()>0)
val=indata;
if(val=="a")
pcf8574.digitalWrite(P0, LOW);
Serial.println("Relay1-ON OK!");
else if(val=="b")
Serial.println("Relay1-OFF OK!");
indata="";
