Threads: 1,298
the hardware connection is no problem. But how to do with software? you have two way:
1. write arduino IDE code by yourself.
2. download open source free firmware to use. such as tamota, but that need you to config setup.
Threads: 1
Which one is more stable?
If the arduino IDE code program is completed, it seems that it can be adjusted by changing the numerical value of the corresponding place at the site.
Also, as an additional function, if the water level drops, I would like to send an email alert. Is that possible?
