Hello admin,
thanks a lot for these really nice PCB, which allow lot of powerful projects!
I've checked the circuits of KC868-A4 (and other KC868-versions) and you are right, the direct GPIO-communication is easier to handle for Arduino-newbies than bus-connected parts.
Nevertheless I found out some optimization for KC868-A4-hardware. Maybe you can use it for an future hw-update.
I intend to rebuild an individual PLC, which controls a heating system (7 kW oven with water heat exchanger) with some DS18B20-sensors, 24V-pump (0-5V-speedcontrol) and safety features. Actual I have to resolder some parts of KC868-A4 to get an I2C-display and RTC, but with the mods it would be nearly a 1:1 change. Also I think it goes more flexible.
best regards
plc
- cancel RS232 (saves lot of space + USB-C is sufficient for controlling the PCB directly)
- change IRD/IRS & 433MT/433MR to 1x I2C-bus (2x ordinary 4-Pin-connectors, i.e. for display & other I2C-parts)
- add a connector for an accurate working I2C-DS3231 RTC-modul
- make the 2x 0-10V-DAC jumperable also to 2x 0-5V (to control 0-5V-devices)
- a relay OR mosfet option would be great (or to get only 1 PCB => 2x relay + 2x mosfet)
- ESP32 on a socket => stackable ESP32 (allows different ESP32-versions (i.e. with external antenna) and change of controller, if there is a problem). I know it's more expensive, but fast changing a small ESP32 is a superior feature. I.e. a company can send only the small ESP32-modul to consumer, if somthing went wrong.
best regards
plc
