ESP32 RF
Lightbulb
Hi! (first of all thx for nice products ;-))
I try to program RF remote.. (on server)
I follow : https://www.kincony.com/home-automation-...moter.html
Flashed the esp i see the codes in the serial monitor but the outputs are not responding..
I think i edit the example right : (just a few buttons to test)
#include <RCSwitch.h>
#include "PinDefinitionsAndMore.h"
#include <IRremote.h>
long int keycode=0;
long int temp_keycode=0;
void setup()
  Serial.begin(9600);
  Serial1.begin(38400);
  mySwitch.enableReceive(digitalPinToInterrupt(13));
  IrReceiver.begin(IR_RECEIVE_PIN, ENABLE_LED_FEEDBACK, USE_DEFAULT_FEEDBACK_LED_PIN);
  if (mySwitch.available()) {
    Serial.print("Received ");
    Serial.print(" / ");
    Serial.print("bit ");
    Serial.print("Protocol: ");
    keycode=mySwitch.getReceivedValue();
    if (keycode==1376533) {Serial1.print("RELAY-KEY-255,1,1");delay(500);}  //toggle relay1
    if (keycode==1376532) {Serial1.print("RELAY-KEY-255,2,1");delay(500);}  //toggle relay2
    if (keycode==16405) {Serial1.print("RELAY-KEY-255,3,1");delay(500);}  //toggle relay3
    if (keycode==16404) {Serial1.print("RELAY-KEY-255,4,1");delay(500);}  //toggle relay4
    if (keycode==4117) {Serial1.print("RELAY-KEY-255,5,1");delay(500);}  //toggle relay5
    if (keycode==5723139) {Serial1.print("RELAY-KEY-255,6,1");delay(500);}  //toggle relay6
    if (keycode==20501) {Serial1.print("RELAY-KEY-255,7,1");delay(500);}  //toggle relay7
    if (keycode==20500) {Serial1.print("RELAY-KEY-255,8,1");delay(500);}  //toggle relay8
    if (keycode==5576131) {Serial1.print("RELAY-KEY-255,9,1");delay(500);}  //toggle relay9
    if (keycode==5575951) {Serial1.print("RELAY-KEY-255,10,1");delay(500);}  //toggle relay10
    if (keycode==5576188) {Serial1.print("RELAY-KEY-255,11,1");delay(500);}  //toggle relay11
    if (keycode==5576179) {Serial1.print("RELAY-KEY-255,12,1");delay(500);}  //toggle relay12
    if (keycode==5576191) {Serial1.print("RELAY-KEY-255,13,1");delay(500);}  //toggle relay13
    if (keycode==5576128) {Serial1.print("RELAY-KEY-255,14,1");delay(500);}  //toggle relay14
    if (keycode==5575987) {Serial1.print("RELAY-KEY-255,15,1");delay(500);}  //toggle relay15
    if (keycode==5575936) {Serial1.print("RELAY-KEY-255,16,1");delay(500);}  //toggle relay16
    mySwitch.resetAvailable();
    if (IrReceiver.decode()) {
        // Print a short summary of received data
        IrReceiver.printIRResultShort(&Serial);
        if (IrReceiver.decodedIRData.protocol == UNKNOWN) {
            // We have an unknown protocol here, print more info
            IrReceiver.printIRResultRawFormatted(&Serial, true);
        Serial.println();
        IrReceiver.resume(); // Enable receiving of the next value
    if (IrReceiver.decodedIRData.command == 0x15) Serial1.print("RELAY-SET-255,1,1"); //turn ON relay1
    if (IrReceiver.decodedIRData.command == 0x16) Serial1.print("RELAY-SET-255,1,0"); //turn OFF relay1
    if (IrReceiver.decodedIRData.command == 0x17) Serial1.print("RELAY-SET-255,2,1"); //turn ON relay2
    if (IrReceiver.decodedIRData.command == 0x19) Serial1.print("RELAY-SET-255,2,0"); //turn OFF relay2
    if (IrReceiver.decodedIRData.command == 0x1A) Serial1.print("RELAY-SET-255,3,1"); //turn ON relay3
    if (IrReceiver.decodedIRData.command == 0x1B) Serial1.print("RELAY-SET-255,3,0"); //turn OFF relay3
    if (IrReceiver.decodedIRData.command == 0x1D) Serial1.print("RELAY-SET-255,4,1"); //turn ON relay4
    if (IrReceiver.decodedIRData.command == 0x1E) Serial1.print("RELAY-SET-255,4,0"); //turn OFF relay4
    if (IrReceiver.decodedIRData.command == 0x1F) Serial1.print("RELAY-SET-255,5,1"); //turn ON relay5
    if (IrReceiver.decodedIRData.command == 0x41) Serial1.print("RELAY-SET-255,5,0"); //turn OFF relay5
    if (IrReceiver.decodedIRData.command == 0x42) Serial1.print("RELAY-SET-255,6,1"); //turn OFF relay6
    if (IrReceiver.decodedIRData.command == 0x42) Serial1.print("RELAY-SET-255,6,0"); //turn OFF relay6
    if (IrReceiver.decodedIRData.command == 0x42) Serial1.print("RELAY-SET-255,7,1"); //turn OFF relay7
    if (IrReceiver.decodedIRData.command == 0x42) Serial1.print("RELAY-SET-255,7,0"); //turn OFF relay7
    if (IrReceiver.decodedIRData.command == 0x42) Serial1.print("RELAY-SET-255,8,1"); //turn OFF relay8
    if (IrReceiver.decodedIRData.command == 0x42) Serial1.print("RELAY-SET-255,8,0"); //turn OFF relay8
    if (IrReceiver.decodedIRData.command == 0x42) Serial1.print("RELAY-SET-255,9,1"); //turn OFF relay9
    if (IrReceiver.decodedIRData.command == 0x42) Serial1.print("RELAY-SET-255,9,0"); //turn OFF relay9
    if (IrReceiver.decodedIRData.command == 0x42) Serial1.print("RELAY-SET-255,10,1"); //turn OFF relay10
    if (IrReceiver.decodedIRData.command == 0x42) Serial1.print("RELAY-SET-255,10,0"); //turn OFF relay10
    if (IrReceiver.decodedIRData.command == 0x42) Serial1.print("RELAY-SET-255,11,1"); //turn OFF relay11
    if (IrReceiver.decodedIRData.command == 0x42) Serial1.print("RELAY-SET-255,11,0"); //turn OFF relay11
    if (IrReceiver.decodedIRData.command == 0x42) Serial1.print("RELAY-SET-255,12,1"); //turn OFF relay12
    if (IrReceiver.decodedIRData.command == 0x42) Serial1.print("RELAY-SET-255,12,0"); //turn OFF relay12
    if (IrReceiver.decodedIRData.command == 0x42) Serial1.print("RELAY-SET-255,13,1"); //turn OFF relay13
    if (IrReceiver.decodedIRData.command == 0x42) Serial1.print("RELAY-SET-255,13,0"); //turn OFF relay13
    if (IrReceiver.decodedIRData.command == 0x42) Serial1.print("RELAY-SET-255,14,1"); //turn OFF relay14
    if (IrReceiver.decodedIRData.command == 0x42) Serial1.print("RELAY-SET-255,14,0"); //turn OFF relay14
    if (IrReceiver.decodedIRData.command == 0x42) Serial1.print("RELAY-SET-255,15,1"); //turn OFF relay15
    if (IrReceiver.decodedIRData.command == 0x42) Serial1.print("RELAY-SET-255,15,0"); //turn OFF relay15
    if (IrReceiver.decodedIRData.command == 0x42) Serial1.print("RELAY-SET-255,16,1"); //turn OFF relay16
    if (IrReceiver.decodedIRData.command == 0x42) Serial1.print("RELAY-SET-255,16,0"); //turn OFF relay16
Thx in advance..
Kind regards,
Matt
do you test with RF 433MHz remote or IR remoter? which one?
Only the rf.. for now, i get feedback in the IDE serial monitor and i reflashed the esp with my codes..only first 8
you can try to download this BIN file, see whether have keycode output by serial port.
Serial1's TXD,RXD pin need define in your arduino hardwareserial config file firstly.
you should use 433MHz RF 1527 or 2262 code wireless remote.
.zip   KC868-Server-wireless-decode.zip (Size: 3.89 KB / Downloads: 676)
Shocked
Ill try egain i will use remote of the D16 thats 1527 right?
KC868-D16 controller support remote by 1527 or 2262 code. the RF receiver module can learn 433MHz signal.
i recieve the RF signal from esp on to computer by the rs232usb in arduino IDE
further nothing the relay work in HA over MQTT http works but remote not
(the arm and esp dont seem to talk)
sorry, i don't understand details , maybe you can take a photo, i want to know which product you are using, how you wire, take a photo is better to understand.
I'm using KC868-server and i try to program the rf remote. To control the 16 outs of the server (with the rf remote)
when you press remote's key, whether "Serial.print" can output message by USB cable?
