Threads: 2
Is it possible to get an 0-10v output from this board instead of PWM?
Threads: 1,403
sure, KC868-AP use for output 0-10v
Threads: 2
02-04-2023, 01:12 PM
(This post was last modified: 02-04-2023, 01:17 PM by mahafree.)
Is it possible to provide an example config to output 0-10v?
I'm using ESPhome and home assistant.
Threads: 2
I'm currently using that config.
Every channel outputs a PWM signal.
Threads: 1,403
sure, just KC868-AP already have led driver circuit on the PCB, KC868-D16 need to add extend led driver.
Threads: 1,403
if you want output dc0-10v, you need to use 10v power supply.
