How can Smart switch panel with rs485 with KC868-E16T and other product
How can Smart switch panel be used and programmed with the KC868-E16T
Attached is a picture and the attachment of the protocol
.pdf   Switch RS 485 protocal.pdf (Size: 966.55 KB / Downloads: 9,192)
KC868-E16T support you write any arduino code download to ESP32, so if you have the RS485 switch panel's protocol, if you can write arduino code, you can do anything.
I have no experience with Arduino codes
I would like to use rs485 switches to facilitate the wiring
So I attached to you the characteristics of the switches that contain rs485 and its protocol
I have a lot of kincony products which contain rs485
And I can't use it
So I attached my question, how can I use rs485 switches with kincony products
different switch panel have different protocol, if you want to use any RS485 switch panel, you need to write the code for decode switch panel protocol, unless the switch panel's protocol compatible with relay board, it's almost impossible.
