USE PCF8574 FOR ESP32 INPUT PORTS
USE PCF8574 IIC EXTEND GPIO FOR ESP32 INPUT PORTS
I am very new working with Kincony 868 A8
I have downloaded the instructions from lesson 20 for installing input ports and copied them in e new sketch.
After uploading I see that all 8 Inports give "pressed key", continiously. Making contact between ground and 1 port (1 to 8) give no change.
The serial monitor stays announcing all ports "pressed key".
Type : Kincony 868 A8 V1.5
Thanks
What is wrong?
you can use this arduino demo code for PCF8574 INPUT function test: https://www.kincony.com/forum/showthread.php?tid=1609
here are all source code for KC868-A8: https://www.kincony.com/forum/forumdisplay.php?fid=23 see this zone is correct.
Hello, it was that what I have done first time. I installed and loaded up 8574-DI but the result is that all 8 buttons stays continiously on "pressed button"
do you have defined IIC pins in arduino config file. you'd better upload screen error image.
Hello, there is no error message. The screen shows every 0,3 sec for all 8 relais :"Key 1...8 pressed". You can only stop the text by switching out the power.
Hello, I have tried again. The serial monitor writes :
Init pcf8574...OK
KEY1 PRESSED
KEY2 PRESSED.....
KEY8 PRESSED
KEY2 PRESSED
KEY2 PRESSED..... continiously
IC adress in sketch :
PCF8574 pcf8574(0x22,4,5)
I made a copy of the download 8574-DI...
post your code, i will test on your code by KC868-A8.
KeyPressed on PIN1
by Mischianti Renzo <http://www.mischianti.org>
https://www.mischianti.org/2019/01/02/pc...asy-usage/
#include "Arduino.h"
#include "PCF8574.h"
// Set i2c address
PCF8574 pcf8574(0x22,4,5);
unsigned long timeElapsed;
void setup()
delay(1000);
// pcf8574.pinMode(P0, OUTPUT);
pcf8574.pinMode(P0, INPUT);
pcf8574.pinMode(P1, INPUT);
pcf8574.pinMode(P2, INPUT);
pcf8574.pinMode(P3, INPUT);
pcf8574.pinMode(P4, INPUT);
pcf8574.pinMode(P5, INPUT);
pcf8574.pinMode(P6, INPUT);
pcf8574.pinMode(P7, INPUT);
if (pcf8574.begin()){
Serial.println("OK");
}else{
Serial.println("KO");
void loop()
uint8_t val1 = pcf8574.digitalRead(P0);
uint8_t val2 = pcf8574.digitalRead(P1);
uint8_t val3 = pcf8574.digitalRead(P2);
uint8_t val4 = pcf8574.digitalRead(P3);
uint8_t val5 = pcf8574.digitalRead(P4);
uint8_t val6 = pcf8574.digitalRead(P5);
uint8_t val7 = pcf8574.digitalRead(P6);
uint8_t val8 = pcf8574.digitalRead(P7);
if (val1==LOW) Serial.println("KEY1 PRESSED");
if (val2==LOW) Serial.println("KEY2 PRESSED");
if (val3==LOW) Serial.println("KEY3 PRESSED");
if (val4==LOW) Serial.println("KEY4 PRESSED");
if (val5==LOW) Serial.println("KEY5 PRESSED");
if (val6==LOW) Serial.println("KEY6 PRESSED");
if (val7==LOW) Serial.println("KEY7 PRESSED");
if (val8==LOW) Serial.println("KEY8 PRESSED");
delay(300);
As nobody finds the reason and as you can see that the result is as 2 is closed without a connection between ground and input 2 there must be a electrical short circuit in the Kincony A8!
It is the second failure of a Kincony A8 on two peaces.
Kind regards
this code is work fine, but you have changed, so your board not work well.
.zip   8574-DI.zip (Size: 650 bytes / Downloads: 674)
NOT use " PCF8574 pcf8574(0x22,4,5); "    our code is "PCF8574 pcf8574(0x22);"
I have told you need set pin define in your arduino config file:
we use NodeMcu-32S board, so do as these photos will be work fine:
thanks for your help, but the same result as before. Key 2 is always closed.
An other question : instead of KC868 A8 do there exist also one with 10 or 12 relais? Or can you connect 2 more relays on the KC868 A8?
Kind regards.
