Schematic of your Tuya adapter ??
Hi
I could not find in forum the tuya adapter schematic. Would you mind to share it please ? I speak of that product: https://www.aliexpress.com/item/10050044...f19cl7KhKI
Thank
Vincèn
here is schematic of KinCony tuya adapter: https://www.kincony.com/download/KinCony...dapter.pdf
How can I reflash the ESP32 on it ? Can I do it through the USB port ? If not how ?
Thanks
sure, you can download frimware by arduino code to ESP32 by USB port.
here is video tour: https://youtu.be/z67pRMLb4Rc
Hello!
Can you bring a schematic of KinCony tuya adapter version 1.4? The schematic above has mistakes.
Thanks
here is pdf file
.pdf   TUYA_ADAPT_V103.pdf (Size: 36.94 KB / Downloads: 600)
(06-27-2023, 01:39 PM)admin Wrote: here is pdf file
Thank you for your replay!
Can you tell me what's the point of place R16 10k and R14 0R together? If R14 is placed, driver U5 will be enabled always.
How can I switch beetwin RS232 and RS485?
RS485 RS232 cannot be used simultaneously and does not require SWITCH. Originally, I wanted to use OE to disable the 485 function
