voice module arduino code for alexa speaker without third platform software
this is arduino code for voice module (ESP8266) control by Amazon alexa. it not need use sinric or any third platform. just voice module connect to alexa cloud server directly.
MAX support device number :10pcs. if want to support more, need change the code, or you can use google find out some code solution.
make sure install espalexa.h library file on arduino IDE.
.zip   KC868-Alexa.zip (Size: 1.49 KB / Downloads: 1,617)
Hi!!
Any plan to do the same with Google home?
Thanks
we are looking for suitable solution.
hello, has anyone already activated the 32 relays of the KC868?
I already tried to add more devices but I have not been successful.
regards
what's your means? can you write your problem details?
Here I'm getting No new device found an error in the amazon Alexa App, while discovering the device.please help me
do you use voice module or raspberry PI for amazon alexa?
i have used this code KC868-Alexa.zip with help of esp32. but discovery error
you can do as this video: https://youtu.be/_w_jyZHOEEQ
I have followed the same video as you mentioned. but same issue.discovery error
