KC868 A8 - Help In Program
Goodnight,
I'm having trouble using the codes to use the PCF8574 of the KC868 A8, using the same code for input and output, I noticed that it already comes with the standard Digital Input 1 > Turn on > Digital Output 1, does anyone have this code so I can work above him?
Thank you very much in advance
you can see this test arduino code for KC868-A8, it have function that INPUT trigger OUTPUT.
.zip   A8-test.zip (Size: 1.88 KB / Downloads: 749)
here is BIN file
.zip   A8-test.ino.nodemcu-32s.zip (Size: 399.75 KB / Downloads: 765)
