KC868-H32B V4.20 new firmware update
improvement:
1. Improve the stability of anti-interference, if ethernet line failure by interference , now will automatic restart ethernet chip.
KC868-H32B V4.20 firmware download:
download the ZIP file , unzip update the bin file for KC868-H32B relay controller by USB-RS232 cable.
.zip   Relay32_V420_210416.zip (Size: 41.53 KB / Downloads: 972)
Hello, I bought the Smart Controller H32bb21010238 in a bundle with KC868-Hx smart controller by RS232 port. I am very satisfied now I wanted to upgrade to firmware V.4.13 to 4.20 and it didn't work. Unfortunately, the controller is now only after restart reachable in the network. Can you help me? :-)
what's your means? can you take a video?
I update with bootlader and Serial V.4.20  after run and reset it stays with V.4.13
do you have download the zip file directly? or you have unzip to BIN file to download?
I have unzip zip file and uploaded the "Relay32_V420_210414.bin" with bootlader serial at the com port. ---- Download ------ Run ---- wait ---- Restart.
Version no. remains V.4.13
Is the version jump too high?
Sorry, I'm writing with a translator :-)
take a photo of your controller. I think you are using KC868-H32L, not KC868-H32B. you have write the wrong firmware to it, so can't work now.
(04-20-2021, 12:33 AM)admin Wrote: take a photo of your controller. I think you are using KC868-H32L, not KC868-H32B. you have write the wrong firmware to it, so can't work now.
[Image: view?usp=sharing]
add technical support whatsapp number: +86-13336170682 user teamviewer remote control your PC to help you.
(04-20-2021, 05:49 AM)admin Wrote: add technical support whatsapp number: +86-13336170682 user teamviewer remote control your PC to help you.
solved.
reset firmware
update 4.01 (Serial)
separate router 192.168.1.1 advertise with cable
update 4.20 (Serial)
search for KC868-Eth-xxxxx
LAN connection 192.168.xxx
Set mqtt
Install the iobroker server
node red
and everything is ok: - =]
Now I can use the controler with buttons, RC, Vis in my own cloud.
thank you for your support
