[Arduino source code for KC868-A4S]-03 DI
#include "Arduino.h"
#include "PCF8574.h"
// Set i2c address
PCF8574 pcf8574_IN1(0x22,4,16);
unsigned long timeElapsed;
void setup()
    delay(1000);
pcf8574_IN1.pinMode(P0, INPUT);
pcf8574_IN1.pinMode(P1, INPUT);
pcf8574_IN1.pinMode(P2, INPUT);
pcf8574_IN1.pinMode(P3, INPUT);
pcf8574_IN1.pinMode(P4, INPUT);
pcf8574_IN1.pinMode(P5, INPUT);
pcf8574_IN1.pinMode(P6, INPUT);
pcf8574_IN1.pinMode(P7, INPUT);
pcf8574_IN1.begin();
void loop()
uint8_t val1 = pcf8574_IN1.digitalRead(P0);
uint8_t val2 = pcf8574_IN1.digitalRead(P1);
uint8_t val3 = pcf8574_IN1.digitalRead(P2);
uint8_t val4 = pcf8574_IN1.digitalRead(P3);
uint8_t val5 = pcf8574_IN1.digitalRead(P4);
uint8_t val6 = pcf8574_IN1.digitalRead(P5);
uint8_t val7 = pcf8574_IN1.digitalRead(P6);
uint8_t val8 = pcf8574_IN1.digitalRead(P7);
if (val1==LOW) {Serial.println("Key1 Pressed");}
if (val2==LOW) {Serial.println("Key2 Pressed");}
if (val3==LOW) {Serial.println("Key3 Pressed");}
if (val4==LOW) {Serial.println("Key4 Pressed");}
if (val5==LOW) {Serial.println("Key5 Pressed");}
if (val6==LOW) {Serial.println("Key6 Pressed");}
if (val7==LOW) {Serial.println("Key7 Pressed");}
if (val8==LOW) {Serial.println("Key8 Pressed");}
delay(20);
.zip   A4S_DI.zip (Size: 651 bytes / Downloads: 513)
