[Arduino source code for KC868-A2]-03 LAN8720_UDP
#include <ETH.h>
#include <WiFiUdp.h>
#define ETH_ADDR        0
#define ETH_POWER_PIN  -1
#define ETH_MDC_PIN    23
#define ETH_MDIO_PIN   18
void setup()
  Serial.println();
  Serial.println("Connected");
  Serial.print("IP Address:");
void loop()
    char buf[packetSize];
    Serial.println();
    Serial.print("Received: ");
    Serial.println(buf);
    Serial.print("From IP: ");
    Serial.print("From Port: ");
    Udp.print("Received: ");
.zip   KC868-A2.zip (Size: 3.15 KB / Downloads: 592)
(03-02-2023, 06:48 AM)KinCony Support Wrote:
trying to compile with arduino ide:
/tmp/.arduinoIDE-unsaved202567-24315-icayej.r967/sketch_jul7a/sketch_jul7a.ino: In function 'void setup()':
/tmp/.arduinoIDE-unsaved202567-24315-icayej.r967/sketch_jul7a/sketch_jul7a.ino:4:25: error: invalid conversion from 'int' to 'eth_phy_type_t' [-fpermissive]
    4 | #define ETH_ADDR        0
      |                         int
/tmp/.arduinoIDE-unsaved202567-24315-icayej.r967/sketch_jul7a/sketch_jul7a.ino:25:13: note: in expansion of macro 'ETH_ADDR'
   25 |   ETH.begin(ETH_ADDR, ETH_POWER_PIN, ETH_MDC_PIN, ETH_MDIO_PIN, ETH_TYPE, ETH_CLK_MODE); //start with ETH
In file included from /tmp/.arduinoIDE-unsaved202567-24315-icayej.r967/sketch_jul7a/sketch_jul7a.ino:1:
/home/zital/.arduino15/packages/esp32/hardware/esp32/3.2.1/libraries/Ethernet/src/ETH.h:160:29: note:   initializing argument 1 of 'bool ETHClass::begin(eth_phy_type_t, int32_t, int, int, int, eth_clock_mode_t)'
  160 |   bool begin(eth_phy_type_t type, int32_t phy_addr, int mdc, int mdio, int power, eth_clock_mode_t clk_mode);
exit status 1
Compilation error: invalid conversion from 'int' to 'eth_phy_type_t' [-fpermissive]
