(SOLVED) Strange behavor ESPHome
Bug
Hi i got a KC868-A128 with ESPHome on it code from this forum
My problem is if i enable Switch (switch.kincony_kc868_a128_a128_light65) the (switch.kincony_kc868_a128_a128_light49) goes on and if i switch (switch.kincony_kc868_a128_a128_light49) does the same switch on and off
if i enable all switches everything goes on except D132 on the board no light
i have attached the code and the log
.txt   ESPHOME LOG.txt (Size: 46.57 KB / Downloads: 445)
.txt   ESPHOME CODE.txt (Size: 43.25 KB / Downloads: 400)
can you add our whatsapp number: +86-15381188302 take a video send to us.
replace these code to your light65, problem will be fixed.
      pcf8574: pcf8574_hub_out_5
      mode: OUTPUT
or you can use the config file have updated.
.txt   KC868-A128-ESPHome_PCF8575_Analog.txt (Size: 40.53 KB / Downloads: 398)
