[Arduino source code for KC868-AM]-03 ETHERNET
#include <ETH.h>
#include <WiFiUdp.h>
#define ETH_ADDR        0
#define ETH_POWER_PIN  -1
#define ETH_MDC_PIN    23
#define ETH_MDIO_PIN   18
void setup()
  Serial.println();
  Serial.println("Connected");
  Serial.print("IP Address:");
void loop()
    char buf[packetSize];
    Serial.println();
    Serial.print("Received: ");
    Serial.println(buf);
    Serial.print("From IP: ");
    Serial.print("From Port: ");
    Udp.print("Received: ");
.zip   AM_ETHERNET.zip (Size: 1.07 KB / Downloads: 524)
