Threads: 2
04-12-2023, 06:00 PM
(This post was last modified: 04-12-2023, 06:02 PM by tatu.)
Hi!
Will this board support 24v input voltage? Item description page says 12V/24V, board marked only 12V? REV: 1.3
Thanks.
Threads: 1,529
yes, it support 12v or 24v. do you want use power supply by DC 24v, or want OUTPUT 24v voltage?
Threads: 1,529
ok, it's no problem. use for 12v--24v dc.
Threads: 0
06-24-2024, 02:52 PM
(This post was last modified: 06-24-2024, 02:53 PM by tofi93.)
And is it possible to use the same 24VDC power supply for both the A64 and the outputs?
Threads: 0
I tested the A64 with 24VDC, but it shows no signs of life. It works with 12V. What could be the problem?
Threads: 1,529
take a whole photo, how you wire.
Threads: 0
I am very sorry, it was my mistake. One of the cable connectors had a contact issue. As I was about to take the photo, I found and replaced it, and now it works perfectly.
