platform: ESP32
board: esp32dev
remote_receiver:
pin: 16
dump:
- rc_switch
tolerance: 50%
filter: 250us
idle: 2ms
buffer_size: 2kb
sda: 5
scl: 4
# Example configuration entry
type: LAN8720
mdc_pin: GPIO23
mdio_pin: GPIO18
clk_mode: GPIO17_OUT
phy_addr: 0
# Optional manual IP
manual_ip:
static_ip: 192.168.1.199
gateway: 192.168.1.1
subnet: 255.255.255.0
pcf8574:
address: 0x24
address: 0x22
# Individual outputs
pcf8574: pcf8574_hub_out_1
mode: OUTPUT
number: 1
mode: OUTPUT
number: 2
mode: OUTPUT
number: 3
mode: OUTPUT
number: 4
mode: OUTPUT
number: 5
mode: OUTPUT
number: 6
mode: OUTPUT
number: 7
mode: OUTPUT
on_press:
then:
- switch.toggle: light1
pcf8574: pcf8574_hub_in_1
mode: INPUT
on_press:
then:
- switch.toggle: light2
number: 1
mode: INPUT
on_press:
then:
- switch.toggle: light3
number: 2
mode: INPUT
on_press:
then:
- switch.toggle: light4
number: 3
mode: INPUT
on_press:
then:
- switch.toggle: relay5
number: 4
mode: INPUT
on_press:
then:
- switch.toggle: relay6
number: 5
mode: INPUT
on_press:
then:
- switch.toggle: relay7
number: 6
mode: INPUT
on_press:
then:
- switch.toggle: relay8
number: 7
mode: INPUT
- platform: remote_receiver
rc_switch_raw:
code: '000101000101010100000011'
protocol: 2
on_press:
then:
filters:
- delayed_off: 200ms
rc_switch_raw:
code: '000101000101010100001100'
protocol: 2
on_press:
then:
filters:
rc_switch_raw:
code: '001111010111001010110100'
protocol: 2
on_press:
then:
filters:
rc_switch_raw:
code: '001111010111001010111001'
protocol: 2
on_press:
then:
filters:
rc_switch_raw:
code: '001111010111001010110010'
protocol: 2
on_press:
then:
filters:
rc_switch_raw:
code: '001111010111001010110101'
protocol: 2
on_press:
then:
filters:
rc_switch_raw:
code: '001111010111001010110001'
protocol: 2
on_press:
then:
filters:
rc_switch_raw:
code: '001111010111001010110011'
protocol: 2
on_press:
then:
filters:
KC868-A8M-ha-config.txt (Size: 5.68 KB / Downloads: 582)
platform: ESP32
board: esp32dev
remote_receiver:
pin: 16
dump:
- rc_switch
tolerance: 50%
filter: 250us
idle: 2ms
buffer_size: 2kb
sda: 5
scl: 4
type: LAN8720
mdc_pin: GPIO23
mdio_pin: GPIO18
phy_addr: 0
manual_ip:
pcf8574:
address: 0x24
address: 0x22
mode: OUTPUT
number: 1
mode: OUTPUT
number: 2
mode: OUTPUT
number: 3
mode: OUTPUT
number: 4
mode: OUTPUT
number: 5
mode: OUTPUT
number: 6
mode: OUTPUT
number: 7
mode: OUTPUT
on_press:
then:
mode: INPUT
on_press:
then:
number: 1
mode: INPUT
on_press:
then:
number: 2
mode: INPUT
on_press:
then:
number: 3
mode: INPUT
on_press:
then:
number: 4
mode: INPUT
on_press:
then:
number: 5
mode: INPUT
on_press:
then:
number: 6
mode: INPUT
on_press:
then:
number: 7
mode: INPUT
rc_switch_raw:
protocol: 2
on_press:
then:
filters:
rc_switch_raw:
protocol: 2
on_press:
then:
filters:
rc_switch_raw:
protocol: 2
on_press:
then:
filters:
rc_switch_raw:
protocol: 2
on_press:
then:
filters:
rc_switch_raw:
protocol: 2
on_press:
then:
filters:
rc_switch_raw:
protocol: 2
on_press:
then:
filters:
rc_switch_raw:
protocol: 2
on_press:
then:
filters:
rc_switch_raw:
protocol: 2
on_press:
then:
filters:
